Temporary Radiator Repairs
    Glen Innes
    49
    Default Temporary Radiator Repairs
    Does anybody know of any temporary radiator repair technicques or products. I was hoping there may be a putty or glue of some type that can be used to do a temporary repair on a plastic tank.
    cheers
    Paul
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    How temporary?
    If you can get to it and clean it properly, just use bog (body filler.)
    If it's just to get a car home that's to be used for parts and will be stripped, put the whites of a couple of eggs into a cold radiator and fill with water.
    If the hole isn't too big, just remove the radiator cap. That keeps the pressure at atmospheric and reduces the size of the leak and is the safest way to get home and not get the system full of crap you later have to try to get out.
    With a metal core, you can just pinch the core closed at the leak using a pair of vice grips.
    Alan S
    Fellow Frogger! Westair's Avatar
    Jan 2005
    Perth
    558
    You can buy a stick of mouldable (?) gunk which will seal fairly well- Something weld -about 25cm long and 25mm diam.
    A tablespoon of pepper will also help.
    1986 Renault Fuego GTX
    1972 Mercedes Benz 280E
    1988 Nissan Trakka Campervan
    1972 VW Kombi
    In business, words are words; explanations are explanations, promises are promises, but only performance is reality.
    Harold Ganeen.
    Perth Western Australia
    2,697
    Default Temp. Rad Repair.
    Quote Originally Posted by Westair
    Is it one of Selley's two part mouldable putties you have in mind?
    Perfect for the job,wash away traces of coolant before applying.
    I have successfully repaired badly corroded thermostat housings and water heated choke spouts with this product.
    PS Westy.I may call you Westy?
    Have you found that elusive late 505 wagon yet.
    If you are still away and out of touch. Don Reimann passed away last week.
    9,223
    Don Reimann? Well, I guess he was a fair age... does anyone know if Elsie Maurice is still alive?
