is it possible to revive a dying jack?
    Fellow Frogger! Jez 405's Avatar
    542
    Default is it possible to revive a dying jack?
    I think my hydraulic jack is on it's last legs. It now only lifts to less half the height it used to when it was new before it goes limp and starts pumping air.
    I released pressure cap and pumped it several times, but that didn't seem to help at all.
    Is there somewhere I can take it to get it 'serviced'? Or do I have to chuck it and get a new one?
    The 405's scissor jack is a bloody nuisance to use...
    1987 Peugeot 205 GTI S1
    1996 Jaguar XJR X300
    1991 Honda VT250 Spada
    1992 Peugeot 405 S (R.I.P. 31/07/2005)
    Jul 2004
    CLARE SA
    2,324
    Jez 405, it sure is serviceable, see Hydraulic Jacks in your yellow pages.
    cheers edge
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,471
    Default Jack Service
    Usually a jack will do that because it is low on oil - is there oil leaking from it or has it been left on it's side and some of the oil drained out?
    Most have a filler plug of some sort - you can add some hydraulic oil and try it - if it goes higher it was low on oil - if not then the seals may be leaking.
    Don't use engine oil - it will damage the seals probably.
    Cheers.
    12,273
    check the oil level in it first
    many hyd jacks are left with the pressure release valve open and they then leak oil out and then in time they won't pump all the way up like the used to
    they are pretty easy to put seals in yourself if you wanted to so long as the chrome is in good condition on the rod and doesn't need rechroming or renewing
    if it does then buy a new jack as it will no doubt be cheeper
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
