I Broke my Ignition switch
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,484
    Default I Broke my Ignition switch
    well it sort of crumbled to a grinding mess yeasterday after work..
    But i can still move it to the on position.. so how do i manually connect a few wires and start it ...
    Is it just a wire from the pos on battery to the top of the dissy, and earthed from dissy to neg or earth on vechile..
    The NRMA guy started for me.. but i was to stupid to ask hiom while he was there what he did.
    I geus i could just moke up a switch and feed it back in to the cabin semi kill switch style for the time being until i can get a new ignition barrel right??
    But yeah... what and where do i connect power upto for it to spark
    Sorry .. its a 83 505 Sti..
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Firstly: Be sure the car is in neutral and the ignition on.
    Then run a wire from the solenoid on the starter to the + side of the battery. I can't speak for Pugs, but on the CX there's a Torpedo connector that is right alongside the battery and in a case such as this, it is just separated and smacked onto the terminal of the battery and it's all go. FYI, the wire to the solenoid is the little one not the big thick mother...
    Alan S
    16,623
    Yep that bullet connector in the CX is a life saver
    To hot wire the car, just run 12volts to your '+' terminal on the coil, then using a screwdriver on most cars you can short the starter soleniod (easiest way). Poogoe owners will need to give more specific information.
    You lucky being a poogoe you can just buy a univers al switch, label it 'start/stop' and throw the ignition in the bin (don't laugh, my '63 ID19 has a starter button and ignition switch you need a key for). Reach under the dash and squeeze the starter switch wires together, punch the starter button and she'll fire first kick Luckily like your Poogoe it has the best theft protection known to man .... A Citroen badge
    Aug 2002
    3,484
    Cheers guys.. my criminal knowledge has just been raised 80%. .
    Lucky for me tho my dirty covered Chrome faded 505 gets mistake for A vk Commondore, which theifs leave, in prefrence to the upmarket VL
