Dialogys
Results 1 to 3 of 3
Thread: Dialogys
    5,073
    Default Dialogys
    Hi, i've got a CD for Dialogys which should work on PC. But i can't get it to work. It needs JAVA and QUICKTIME. I've installed both but only get a blank screen.
    Is there someone in Melbourne with KNOWLEDGE who could help. Not concerned about paying for the service.
    JoBo
    1,160
    From what i've "read"...
    You need to remove ALL instances of Java & Quicktime that are on your machine, you then need to navigate to the install folders on the Setup CD & install those specific versions, NOTHING else will work.
    When you install QuickTime, you need to do a "Custom install" & then select "QuickTime for Java".
    Then install the Java with all defaults.
    Should be OK after that!
    5,073
    Thank You, i'll let you kow if it works
    JoBo
