Anyone removed car tint before
Results 1 to 10 of 10
    2
    Default Anyone removed car tint before
    Hey all,
    The tint on my rear window (306) is starting to peal and looks absolutely shocking. Not sure if I am going to get a retint. Just want to remove the tint for now. ANyone tried before?
    How hard will it be.
    Advice appreciated.
    12,256
    Quote Originally Posted by TheGreekFrog
    Hey all,
    Advice appreciated.
    you will need acetone, razor blade, good window cleaner and a strong stomach
    using a rag or brush put the acetone on the tint and using the razor blade gently scrape the tint off
    you will need more acetone on the glass to remove the residue from the tint glue and then you will need the window cleaner to clean the glass
    you will need plenty of time and a strong stomach as the smell of the window tint glue is pretty strong and not a very good smell
    the other way around it is to get someone else to do it at around $100/window
    i have done it quite a few times now and i don't envy the blokes that do it for a living
    1 x '98 306 GTi6
    8,176
    Icon4
    Rear window.. extreme caution working around your heater strips, peel as much of the tint as you can (use a hair dryer to soften adhesive) before taking to it with a razor. Good luck not a fun job.
    08 C5 X7 HDi very Noir
    melb
    4,377
    try & strike a deal with a window tinter, remove old tint+reapply a new tint & i'll give you whatever amount you deem appropriate. I too have crappy window tinting & am planning to remove & reapply mine. It seems like an easy job to do (removing tint) but the hassel of doing it is what turns me off
    2
    Advice already taken. I did some research and found this tips page and are going with them to remove the tint and get them to re-tint my windows. It all looked too hard. Here's a tinters way to remove tint.
    Tint Professor
    WLB
    WLB is offline
    1000+ Posts WLB's Avatar
    Warragul, Vic.
    1,103
    Tint Professor
    Glad wrap works quite well too, applied over the wet film. It stops the water from evaporating. Also, for side windows, wet newspaper held in place with a piece of carton cardboard (corrugated) and masking tape. If you know a doctor, borrow his pin-wheel (a skin sensation tester) and carefully run it back and forth across the film. It's like a pizza cutter with needles and will perforate the film and let the water in faster. The glue is water soluble so acetone is best avoided if possible, as it creates a sticky mess.
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,383
    Take previous advice!
    I recently had 2 rear door wind-up windows tint removed and renewed at $66 each.
    This was quality 3M tint job.
    The agent did not take Visa so I filled in the waiting time by walking to the nearest ATM to get cash - about 45 mins each way.
    When I returned car was parked outside - finished - too easy!
    Having previously removed tint from one hatchback rear screen myself, I would never do it again.
    I guess the rear screen would cost a bit more, but I believe it is about $300 for the whole car (Remove old tint & replace with new). Good value.
    Good Luck.
    WLB
    WLB is offline
    Warragul, Vic.
    1,103
    Quote Originally Posted by Fordman
    If you were working an old car with easily removed door glass, just soak it in the bath. It will come off quite easily.
    But I'd never do it again either. It's money well spent. (Like repairing punctures).
    65
    Yes, I have (several times), no trouble at all!
    Moisten the film with spraying thinners; after a few minutes it will be softened; lift an edge with a blade and pull off in sheets; clean-up all the glue residue with thinners.
    N.B. Don't get thinners on anything else.
    Caution - Fire ! :
    (Don't ever risk a hair dryer, or any other potential heat/spark source, near flammable liquids and fumes)
    NORTH PERTH W.A.
    830
    the steam from a kettle works well on the delicate sections ie rear window with demister . I'd stay away from the solvents if you want to still have a liver unless your drinking the stuff
