Petrol
Thread: Petrol
    Fellow Frogger! Inspector Clouseau's Avatar
    Dec 2002
    North Coast NSW
    188
    Default Petrol
    I suspect this might generatye some debate:
    A former army aircraft mechanic blew my concept of the various petrols completely out of the....sky yesterday.
    I think this is the summary of his theory- octane is purely a measure of the anti-knock quality of petrol. A petrol that has more octane has less heptane and heptane is what generates the power. So standard unleaded in a motor properly tuned etc should generate more power and efficiency than a high octane petrol.
    Is this so? Does anyone have any info?
    16,375
    Yep,
    this is correct. Higher octane only prevents knocking. If you have a high compression motor or turbo'd motor, sure you can get lotsa power out of it on standard petrol, you'll also hole a piston if it pings to badly .... Like everything it's a comprimise.
    eg: i seem to recall deisel actually has the capability of making more power than the same amount of petrol
    Fellow Frogger! OddFireV6's Avatar
    152
    Octane rating is of course the likelihood a fuel will detonate, LP gas is 110 Octane in Victoria, that’s why my turbo 505 runs on straight gas. I can wind up the boost on a standard compression motor and more than compensate for the lower energy or heat value of Gas in comparison to Petrol.
    A low octane high energy fuel will not work well in a high compression motor, detonation will rob power and eventually damage the engine.
    Higher octane allows you to increase compression and/or turbo boost and derive more power. It’s a fact though that engine power is also proportional the energy value of the fuel and that the energy value of a fuel is not directly related to octane rating.
    OddfireV6
    504 V6 24V, 203
    6,248
    Higher octane fuel actually burns more slowly than lower octane fuel.... Knock happens when the pressure peaks caused by pre-ignition move faster than the speed of sound.
    They've actually both got very similar energy per litre - premium is a liitle bit more dense and therefore stores more energy per litre, but only a tiny bit.
    Stuey
