Swapping BSI and vin coding
Results 1 to 19 of 19
Like Tree8Likes
  • 4 Post By dmccurtayne
  • 1 Post By dmccurtayne
  • 1 Post By Stuey
Thread: Swapping BSI and vin coding
    Jul 2013
    Newcastle/ central coast
    2,125
    Default Swapping BSI and vin coding
    With the amount of bsi replacements going on it was only a matter of time before this happened.
    So car is a 307 HDi 2006
    Bsi keys and engine ecu replaced due to some fault by old owner.
    Car was then presented to ďaĒ dealer for a replacement key.
    Then car had sat for over a month as a non runner.
    Short story long the code in the bsi was wrong for the car because the vin had been changed to the new car and obviously peugeot canít know any better.
    New owner was quoted for a new bsi and engine ecu because at dealer level this is the only warrantable option.
    Effectively writing off the car.
    I was able to fix in about 10 minutes because I have a code grabber and Iím a nice guy.
    But this should serve as lesson not to change the vin in the bsi just change the radio vin thatís all thatís needed and that way a tech with half a brain ( in short supply ) can figure out whatís wrong and get it going.
    4008
    Gone but not forgotten C5 x7 3008 206 GTI 180 306 XR SED 405 MI16 x2 xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    COL, dimistyle, JoBo and 1 others like this.
    Garage C5 X7 4008
    6,529
    David, can you explain what you did to fix it? I'm a bit thick when it comes to BSI's etc. Did you recode the BSI or reset the stored VIN somehow?
    2003 PEUGEOT 206 GTi
    Aug 2016
    Sunshine Coast, QLD
    927
    Code grabber now you're talking.
    Yes never change the VIN set on the BSI.
    You need to know the key code of the BSI to reprogram keys and a few features in the BSI without it you're locked out and the dealers can't help you.
    Jul 2013
    2,125
    Sorry below
    4008
    Garage C5 X7 4008
    Jul 2013
    2,125
    Quote Originally Posted by dmccurtayne View Post
    No I have a tool that can extract the key code from the bsi to enable a key be programmed. Without removing the bsi and dismantling.
    Then just needed to code a key.
    A bit embarrassing to the dealer that called me after the customer blew up.
    Sorry to be clear the problem became that peugeot couldnít know what the key/pin was because the vin number that is associated with that bsi on the as built data on the psa main server is gone and the pin/key that comes up is the one that is associated with the bsi/engine ecu thatís in the bin.
    4008
    4008
    Garage C5 X7 4008
    Jul 2013
    2,125
    Quote Originally Posted by dimistyle View Post
    You can clear the EPROM but thatís beyond my level of could be bothered with the old bsiís you could run the battery low and crank it till it has a mental brake down and clears itself but that wouldnít help in this instance.
    4008
    Garage C5 X7 4008
    6,529
    Ahh, gotcha.
    Aug 2016
    Sunshine Coast, QLD
    927
    4008
    Arh yes had a enquiry from a 307 owner that was adamant the BSI was a teapot and wanted me to reprogram it by sending it to me....no sir I need the car with BSI connected, The 307 was not in QLD so I think it went to Mr scrappy.
    Kids had left radio on until battery died then they cranked it to fully dead.
    Does this make the BSI a virgin unit again and can program from scratch?
    Could be useful at some stage??
    Jul 2013
    2,125
    Yes it clears all configuration matching and pin code data. Basically making it new again.
    4008
    dimistyle likes this.
    Garage C5 X7 4008
    5,260
    4008
    So, if one changes a battery on these cars without continuing power supply to the computers the BSI etc will need re-coding after???
    Just as well i didn't listen to the Renault dealer mechanic. I asked if i could charge the battery on the Megane without disconnecting it from the car. Answer was yes but it's safer to disconnect and charge. He didn't tell me to keep the system on a battery while doing so.
    "The enemy of knowledge is not ignorance, it's the illusion of knowledge"
    Stephen Hawking
    Jul 2013
    2,125
    Yes it can cause this but you basically need to crank it until the gauges flick and it buzzes and carries on not something that you can do just by just changing the battery
    4008
    JoBo likes this.
    Garage C5 X7 4008
    6,529
    JoBo I've disconnected the battery from the 206 for days on end and it's no problem, as long as you've let the BSI go to sleep - basically left the ignition off for ten minutes or so until everything's shut down (on the advice of Mr Mcc above). I didn't even need to retune the radio (but the clock did need resetting).
    JoBo likes this.
    5,260
    Interesting! I rigged something up so power stayed on while changing battery to be sure, to be sure
    Stephen Hawking
    Armidale
    2,488
    Quote Originally Posted by JoBo View Post
    My D9 (Series II) 406 has a BSI, which has never given me trouble no matter how battery was disconnected! Thank goodness, as I've had plenty of other electrical faults, and at times given the BSI a rough trot.
    When deliberately disconnecting the battery, I've gone through the process of winding down driver's window & opening bonnet, then allowing the BSI time to nod off before disconnecting battery. On reconnecting, I reached through the open window and turned on the parkers to gently wake up the BSI. This always works as it is supposed to.
    However, the car has a quick release positive clamp, which I must get replaced, as it releases a bit too easily. I've now got it tied shut, after it came adrift in traffic a couple of times, causing the car to not just stall, but appear totally dead! Also caused me to jump out and reinstall the clamp as quickly as possible before the horns started blowing.
    It seems that problems occur if the voltage is allowed to drop lower and lower while the battery is connected and the BSI is wide awake - not so much if there's a sudden disconnect wt a time when voltage is good.
    Alec
    Manly West, Brisbane
    369
    Very interesting but you lost me with the heading. What is a BSI? I know what a VIN is. I sooo love acronyms.
    5,260
    Body System Interface
    Stephen Hawking
    5,260
    Stephen Hawking
    Oct 2002
    Melbourne Victoria
    12,118
    Icon14 swapping-bsi-vin-coding.
    Gosh I thought it was [email protected]@dy Stupid Interface.. you learn something every day.!
    Nice thread.
    Ken
    Jul 2013
    2,125
    Itís actually called a built in systems interface.
    4008
    Kenfuego likes this.
    Garage C5 X7 4008
