Trip Computer 206
Results 1 to 7 of 7
    Jul 2019
    south africa
    4
    Default Trip Computer 206
    Heya All..2 Questons I Own A Peugeot 206 1.6 16v 2003 And Need To Know If The Car Has A Trip Comp?? I Have The Button On The End Of The Wiper Stalk And 3 Line Display But The Button Does Nadda..Nothing At All And Would Really Appreciate That Kind Of Info Displayed In My Frog..Also Have A Clunk Noise On The Front Right Suspension And Not Sure If Its The Shock Mounting That Has Deteriorated Or Something More And Is There A Way To Fix It If It Is The Shock Mounting Until I Can Get It Permently Repaired? Cheers
    Jul 2013
    Newcastle/ central coast
    1,857
    In Australian spec cars yes they do but being a SA car I would need the vin to check in any advent you can configure using a diagbox, with the knock I would be looking at sway bar links or control arm bushings
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Jul 2019
    south africa
    4
    Default 206 Trip Comp
    Thanks Man That Helps Alot, My Vin No. Vf32ANFUF42909331 If You Are Able And Willing To Check, Where Could I Have Something Like That Done And The Kock Is When Going Over Bumps..Mostly Minor And Near The Top Of My Suspension
    Jul 2013
    1,857
    You would need to get to a dealer or someone with a diagbox to activate this on the display.
    Garage C5 X7 4008
    Jul 2019
    south africa
    4
    Default 206 Trip Comp.
    1 More Thing I Need To Know, I Had My Timing Belt Done Last Year, Have Done My Own On Previous Cars But This Was Done By A Mechanic..New Tensioner Kit And Belt..Is It Normal For This Cars Cam Belt To Be Tight,meaning That When I Checked The Give On The Belt I Found Very Very Little And Afraid It Will Cause Premature Wear.
    Jul 2013
    1,857
    No if itís over tight it will squeal
    Garage C5 X7 4008
    4,366
    Not confusing timing belt with accessory belt?
    I agree, the front end knock is most likely stabiliser link - relatively easily replaced.
    KB
