loading photos to my posts.
Results 1 to 7 of 7
  • 1 Post By WLB
Thread: loading photos to my posts.
    Jan 2013
    Geelong
    556
    Default loading photos to my posts.
    I've had no such problems to date but this site now refuses to download photos that are bigger than 100KB.
    I've checked back. It's handled them easily before up to about 140KB
    Now anything over 100 gives me a red exclamation mark.
    And I'm on the lowest size setting on my camera
    What has happened?
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility
    1962 Renault Dauphine Gordini
    1950 Grey Fergie Tractor (Pending Resto Project)
    9,249
    As stated. The site is reducing its data volume. Less to store, and less to serve.
    It isn't hard to find software for whatever system you use to decrease jpeg "quality", ie increase compression, with accompanying loss, which is sometimes a problem.
    The way jpeg works handling transitions suggests that if you are desperate to get something still readable at that size, consider putting the image through a very mild gaussian filter before compressing. It usually isn't needed.
    977
    Or find somewhere else to store them, and link - although that causes major annoyance if you decide to delete them later.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, AT Power Dry Sump, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Custom Radiator and Oil cooler, 3J Plate LSD, E85.
    Sandown - 1:31.5, Winton - 1:40.2, Wakefield - 1:11.05, Phillip Island - 1:55.9, The Bend (International) 2:23.2
    WLB
    WLB is offline
    1000+ Posts WLB's Avatar
    Warragul, Vic.
    1,130
    geodon likes this.
    Jan 2013
    Geelong
    556
    Default Another glitch
    Thanks!
    FastStone worked fine after using Good Ole YouTube for a tutorial
    BUT now the photos have no image on the thumbnails just a white question mark.
    When I click on it I get the error message " This asset is not being used by any content that you have access to".
    1949 Citroen Big 6
    1955 MGA1500
    WLB
    WLB is offline
    Warragul, Vic.
    1,130
    I'm confused now.
    Either I misunderstood your original problem, or you've misunderstood something.
    Could you explain, step by step, what you're trying to do and how you're doing it. Something doesn't make sense.
    bob
    bob is offline
    May 2001
    Skipton
    2,472
    G'day,
    .......The way jpeg works handling transitions suggests that if you are desperate to get something still readable at that size, consider putting the image through a very mild gaussian filter before compressing. It usually isn't needed.
    and fantastic for getting decent images from printed pages without the hassles of de-screening....
    Increasing JPG compression from the usual 80-90% to around 50% works wonders for image size, PNG works better for textual materials - when Murphy isn't looking over your shoulder...
    cheers,
    Bob
