Cast alloy repair
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By driven
  • 1 Post By 1972Ren
Thread: Cast alloy repair
    1000+ Posts Dano's Avatar
    Apr 2012
    1,367
    Default Cast alloy repair
    The heater tap body on the 404 is stuffed. I have a secondhand one which is better, but it is showing signs of corrosion internally and a little where the hose has been sitting. The image below is the existing one.
    My thinking is/was, is there an epoxy of something that would,
    A. Adhere to the internal surface.
    B. Be heat resistant
    C Will this idea work/solve the problem long term.
    Any thoughts/input would be greatly appreciated.
    Dano
    9,247
    It can depend on how bad it is. Refrigeration suppliers carry epoxy sticks that are used to patch and plug aluminium evaporator coils. This might do. It is extremely difficult to do anything soldering or brazing with die cast zinc alloys.
    The ultimate repair for a concourse-like finish is to clean it up and get it copper plated. This will accept solder.
    1000+ Posts driven's Avatar
    Apr 2005
    1,519
    Get the best stuff for this
    https://www.muggyweld.com/product/super-alloy-1/
    Expensive but can even repair a hole in a VB can
    https://youtu.be/D5Xz9Y97zvI
    Dano likes this.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,757
    Don't suppose anyone has a good one laying around?
    9,247
    Are you sure Muggyweld will do die cast alloy? Is it not for aluminium?
    Feb 2018
    Australia
    808
    Hi,
    muggyweld.com have several sticks and say Super Ally 1 will solder these metals.
    I have used the aluminium repair sticks and they really are as good as claimed.
    Dano likes this.
    9,168
    How hard would it be to machine that thing out of say brass or aluminium and be done with it forever?
    I don't see how you will ever clean the internal corrosion properly like they show in that video.
    As an epoxy for external use you could try JB weld or similar.
    Even simpler, how about using a more modern part from another car?
    ACHTUNG ALLES LOOKENPEEPERS
    Jan 2012
    Gold Coast
    202
    That corrosion is in the heater control valve it will be clogged up inside and not repairable buy a new valve bolt it to the copper heater radiator and pressure test.
    Apr 2012
    1,367
    Thanks for all the responses.
    Certainly plenty of options to think about.
    6,647
    Devcon make some good putties that might work.
    2003 PEUGEOT 206 GTi
    Avisford NSW
    552
    Do Muggyweld have an agent in Australia?
    Feb 2018
    Australia
    808
    Hi,
    I bought the aluminium sticks I have used, via a website in NZ. It wasn't actually the Muggyweld brand, but they are all the same thing.
