Peugeot 508 Allure 2012
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By seasink
  • 1 Post By dmccurtayne
Thread: Peugeot 508 Allure 2012
    Mar 2015
    5
    Default Peugeot 508 Allure 2012
    Bonjour all
    my 6 year old peugeot 508 has just started playing up: when stopped in traffic or at red light, it kicks forward when i start driving again. It happens mostly if the temperature gauge reaches 90. I release the brake and the car bolts! There are no problems whilst driving, it only happens on stop and start. My auto transmission mechanic put the car through his workshop computers that did not detect any major fault, but he does not have the Peugeot software.
    Is there any one who had same problem or could give me a clue on the fault? Also can anyone recommend a reliable Peugeot mechanic in Sydney, not too expensive...please?
    Thank you so much, Marie
    9,344
    Sydney is a big place. Where are you located?
    Mar 2015
    5
    Bankstown area but i do not mind travelling
    9,344
    Three come to mind -
    Colliers, Granville - https://www.colliersauto.com.au/ - long standing independent Peugeot mechanic;
    Revivemylion - comes to you - http://revivemylion.com/Contact-Us.php
    Continental Cars - Roselands - https://www.citroencentre.com.au/
    The last was a very long term Citroen dealer, but no longer sells them new after Inchcape took over importing. Your 508 is very close mechanically to a Citroen C5. The workshop would know it's insides well.
    jaahn likes this.
    Jul 2013
    Newcastle/ central coast
    2,222
    You should be taking it back to the dealer being 6 years old and if you have looked after it you may get the transmission replace for free or may only need to pay labour have a look back at some previous threads where this has happened I know they love to shit on the dealers here but peugeot and cit a really good at out of warranty repairs if it is .a. Common issue or .b. Not reasonable to see something fail that quickly but as normal please return once fixed and tell AF you experience to many just run off and others donít benefit from your situation also whatís the mileage of the car ??
    Garage C5 X7 3008 XTE
    Gone but not forgotten 206 GTI 180 306 XR SED 405 MI16 x2 505 GR xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    GreenBlood likes this.
    Garage C5 X7 4008
    Jul 2013
    2,222
    AM6 Fluid AM6 Fluid
    Garage C5 X7 4008
    Mar 2015
    5
    Good morning and thank you for your feedback, Seasink and Dmccurtayne.
    I had bought the car second hand 2 1/2 years ago, it was always serviced and well maintained, it has 135000kms now, no other problem. I love that car.
    We will ask Continental in Roselands as we had bought a great C5 from them years ago.
    I looked at the old thread about the fluid, thank you for pointing it out, Dmc.
    I will write back as to the end result about the jerk problem on my 508, as it could help other car owners, like i myself am thankful to have found this forum.
    A bientot et merci,
    Marie
    Mar 2015
    5
    Good morning all,
    We took the 508 to a peugeot dealer yesterday for assessment, and here is the report:
    "Job: check for clunk noise when putting into park, reverse and into 1st gear."
    - road tested vehicle and found engine hesitation on changing from position "N" to position "D" / or changing from "N" to "R".
    Found TSB applicable, carried out programming of gearbox positions. Retested all OK . Customer to monitor.
    Recommendations:
    - Top link rod split - requires replacement.
    - top engine mount going soft: requires replacement.
    Could you please give me your feedback on the above report. I haven't driven the car yet except the short distance from Peugeot to home.
    The programming of the gearbox: is this as simple as that? Just a matter of fixing a problem with a computer?
    What is TSB. ( i should have asked more questions, but the service person was a bit fast!)
    What do you think about the top link rod split? Is this a reason why the engine mount is going soft?
    I appreciate all feedback, thanks a lot,
    Marie
    Jul 2013
    2,222
    That top link can cause this bang feeling but from what I have seen it a symptom not the cause
    Garage C5 X7 4008
    9,344
    TSB is probably Technical Service Bulletin. A recommended fix for problems found in continued usage, issued by the manufacturer.
    Mar 2015
    5
    My husband changed the link rod (dogbone) this morning. (Genuine Peugeot part,$129.- at Trivett, dearer elsewhere )
    The link rod is relatively easy to replace.
    Unbelievable how bad the rubber was on the old one: like a piece of swiss cheese, hardly attached to the metal!
    Car tested ok so far, we are taking a drive to Wollongong tomorrow and hopefully there won't be any more bolting/surging at traffic lights or stops/starts.
    I want to mention that Spare parts employee at Trivett' was very helpful with explanations, diagrams, advice, great to deal with people who know their job and share!
    Marie
