2002 C5 Serious suspension fault
Results 1 to 2 of 2
    Dec 2010
    Sunbury Australia
    11
    Default 2002 C5 Serious suspension fault
    The wife hit a big pothole RH side the other day, Serious suspension fault comes up, the pump does not work anymore so cannot use the suspension height adjustment. Have checked fuses relevant in glove box and under hood (not the maxi fuses ), has anyone had a similar experience. I feel it might be the RH side Height Sensor. Height is OK for driving. We only use it as the second car for local shopping.
    Aug 2016
    Sunshine Coast, QLD
    935
    Is there still a error appearing at start up, never had an issue with the suspension but would try the battery discount and reconnect following the proper procedure if error code is still being displayed?
