Shed
Results 1 to 25 of 32
Like Tree24Likes
Thread: Shed
    Fellow Frogger! Balki's Avatar
    Ulverstone/Tasmania
    593
    Default Shed
    Just some pics of the shed im building to put my cars in, its 20x12 meters with 3.8 meter wallsShed-img_4771.jpgShed-img_4768.jpgShed-img_4767.jpgShed-img_4769.jpgShed-img_4770.jpgShed-img_4773.jpgShed-img_4774.jpg
    UFO, Shoji, SLC206 and 4 others like this.
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    SWOTR
    2,965
    I have shed envy and you've only got as far as the slab!
    bluey504 and FIVEDOOR like this.
    Fellow Frogger! Dano's Avatar
    Apr 2012
    587
    And I thought 6x9 would be big enough. I too have big shed envy
    CitroŽn Tragic UFO's Avatar
    9,222
    It's not big enough. As you will discover...
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    7,423
    I concede, yours is definitely BIGGER than mine.
    John
    15,491
    If its not a rude question... what sort of price is a slab like that (ie: properly done ). I've noted you can buy 20 x 12 barns for about $20K. So that would be 4meter bays between any uprights inside the shed. 20K seems cheap for such a big shed with a high bit in the middle for hoist/machinary/caravan.
    8,482
    I bet the workmen had never seen a Cactus before. There can't be many in Tasmania.
    Tadpole Hatstand40's Avatar
    Aug 2017
    AU
    22
    Envious beyond belief. I've only got a 9x5.5.
    Sent from my E6883 using aussiefrogs mobile app
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,178
    Hi Shane
    I think rule of thumb is the slab will cost what the shed kit itself cost.
    CXVingtCinq likes this.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,091
    Slabs are expensive. My approach is more shed, less slab. Concrete is handy in a workshop, for cleanliness, straightness of assembly, ease of finding fallen objects, and convenience of moving stuff around. But for storage of big things like cars gravel is fine. And for mechanical work on a gravel floor I find a rubber mat makes a good surface and is softer and warmer than concrete. One of my sheds is 30 by 10 metres and has concrete in only two of its five bays.
    Another issue is the decision about how wide a shed should be. Too wide and it is hard to remove stuff from the back of it. Too narrow and building costs rise. One of my sheds is 15 m square and it is painful to get machinery in and out. It has only one 3 m wide door in the middle of one wall so I arrange everything in a sort of semi-circle and keep only easily moved things like tractors in the access area. It came with the property so I am making do with it. But when I built the 30 by 10 m shed I put sliding doors all along one wall. I suppose I should not that I have no space restrictions.
    Still, nice work, Balki, and admirable commitment. I like your 550: so much more tractor than a 35 or even a 135.
    Roger
    My Supermodel 63-1092's Avatar
    somewhere! Pilbara, Bowen Basin, Melbourne?
    10,092
    20x12x.1=24
    24x$200? a cube= $4000 to $5000
    Add steel and timber doing yourself $8000 to $10,000
    Pay someone to do it $20,000
    John
    Александър Кристоф Шанел
    15,491
    Roger
    I have lots of crappy sheds I just want one nice one ... with some decent height in some areas ... a floor that won't sweat moisture through winter ... and access that allows me access to each car. ( Yes I'm dreaming ). I was thinking barn with 3 roller doors each end (that gives access to 6 cars/caravans/machinary/etc without starting the "move the CX, move the DS, drag the caravan out ... now we can get the traction out" type thing.
    tractor implements would drive you nuts. I figure just put a series of low dog kennel height roofs around the edges of one of the sheds so you an dump any implements onto shipping pallets and have a roof over them. you never want the things buried so it takes you an hour of moving them around to get to the one you want.
    Fellow Frogger! CXVingtCinq's Avatar
    Jun 2015
    Narrabri, NSW
    700
    As with most things, you generally get what you pay for.. I have 12m x 8m and as UFO says, whatever you go for it won't be enough. The slab is usually about one third or a bit more of the total cost of a decent shed but this depends on the quality of the slab and reinforcing and quality / gauge of the shed steel. Insulation.? Electricals.? Plumbing.? It all adds up.
    But in the end you can't beat a good shed. And you sure look to have the makings of a good shed..
    Cheers, Peter J
    Current - 1984 CX 25 IE
    1976 16TS
    Previous - 1976 16TS : 1979 12 Virage
    Brisbane/Australia
    1,679
    A carport would be nice.
    "I cannot help but notice that there is no problem between us that cannot be solved by your departure."
    SWOTR
    2,965
    Quote Originally Posted by REN TIN TIN View Post
    Yep, a carport would be nice!
    15,491
    Quote Originally Posted by Peter Chisholm View Post
    He might be putting one down one side of it .... with a gravel floor.... for the tractors and trailers ( I would if I could!)
    SWOTR
    2,965
    One can never have enough sheds and carports. An aircraft hangar anyone?
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    18,253
    So true, see what happened here, unfortunately, not my problem
Name:	see what happens.jpg
    Every day is a good day
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,178
    Quote Originally Posted by FIVEDOOR View Post
    That would be a nice problem to have.
    FIVEDOOR likes this.
    Regards Col
    1973 Alpine A110
    8,482
    That's a dentist in the UK who owns a chain of clinics. Paid for by decay!
    Sep 2012
    Bombira, NSW
    195
    The ideal shed should allow for all types of maintenance, this one allows for testing of your turning circle etc!
    COL and CXVingtCinq like this.
    SWOTR
    2,965
    It looks very lonely sitting there all on its own. To keep it company, I reckon we could round up between us lots of cars to fill up a few spaces.
    Jun 2011
    Brisbane Qld
    18,253
    If it was mine, I'd set up a gymkhana course.
    COL likes this.
    Brisbane/Australia
    1,679
    No, not for Balki, for me.
    Forget about a 20 metre shed, I dream of having just a carport. (A double carport would be even better).
    My cars live outside and any work is done in the driveway (weather permitting).
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,178
    3 of my cars live in the shed and garage, but because the shed and garage are full I have to move the cars outside to work on them.
    Actually I prefer to work outside as the natural light is much better than working under flouro lights.
    Regards Col
    1973 Alpine A110
