307 hdi wont start
Results 1 to 9 of 9
    Sep 2017
    Bellawongarah
    4
    Default 307 hdi wont start
    Hi, my 2008 307hdi 2.0l cranks but wont start. You can bump start it very easily. A small push and it starts immediately. The local PUG dealer thought it was a high pressure pump problem. I removed and cleaned the pump and it appeared in perfect condition. A scan tool comes up with both low and high fuel pressure. The car runs perfectly when bump started, but will not start off the key. It will crank but not fire. Could it be the immobiliser? Any help would be appreciated.
    7,478
    My suspicion is that the starter motor, though turning, hasn't the torque to turn fast enough under load. You may need a new one. From not always reliable memory, the dealer software can indicate the cranking rpm. Check with your tool.
    Cleaning the HP pump is a worry - I hope you didn't dismantle it.
    Sep 2017
    Bellawongarah
    4
    Its cranking fast. Disassembled the high pressure pump and put it back together and car is running fine except i have to push start it. It starts immediately as you let the clutch out. I'm sure its electrical or computer related. I tried starting it by having the key on and shorting straight across the starter solenoid, but it just cranked over quickly with no start. I then disconnected the starter solenoid power supply so as to bypass the key and powered the solenoid directly. Still no luck. Give me old mechanical injection anyday.
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    415
    What sort of mileage is on it definitely not the immobiliser I have done starters on these and the V6s for hard to start issues have you swapped batteries ( charging doesnt solve it)
    Sep 2017
    Bellawongarah
    4
    258000k's. Tried a new battery and it made no difference. It is cranking over a lot faster than us push starting it. I was told it could be the chip in the key. But that doesnt explain how it push starts.
    Jul 2013
    415
    It cannot be the key
    Sep 2017
    Bellawongarah
    4
    Had an auto electrician plug his scanner in and said it was a high pressure pump problem. Not enough pressure at cranking. Only 40 bar when it should be 200. Peugeot dealer diagnosed the same saying it was low pressure. My own diagnostic tool shows two faults...low pressure and high pressure!Well, swapped the high pressure pump and no difference. Still wont start. Im wondering if it could be the common rail pressure sensor. It bump starts on the replacement pump. The dealer lent me their test pump, so its ok. I think the problem must be computer or electrical.
    Jul 2013
    415
    Lol
    Aug 2016
    Sunshine Coast, QLD
    595
    Quote Originally Posted by ken watson View Post
    Any progress Ken?
