V6 Cylinder map
Like Tree2Likes
  • 2 Post By Fordman
Thread: V6 Cylinder map
    Dec 2015
    2
    Default V6 Cylinder map
    A dufus question i know :-) Getting misfire detected on cylinder 5 of my 2005 3.0i V6.
    Can someone help with ID cylinder Number sequence.
    Based on threads on other forums it should be
    Firewall
    6 5 4
    3 2 1
    Radiator
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,382
    Quote Originally Posted by Haywardz888 View Post
    Firewall
    6 5 4
    3 2 1
    Radiator
    I assume this is a V6 laguna.
    Its the middle cylinder on the rear bank, it will be the pencil coil that is faulty and you will need to remove the inlet manifold to get access.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    Dec 2015
    2
    Thanks Col. Its a V6 Exclusive.......and its been an exclusive pain in the butt dropping one of the rear coils.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,382
    They are the ones that usually go, because of the heat trapped under the inlet manifold.
    Regards Col
    1973 Alpine A110
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,244
    A word of warning: depending on the fault code analyser you are using, sometimes the codes are in Firing order. IE, if firing order was 1-5-3-6-2-4 then the fault code Cyl 5 may refer to actual cylinder 2. Worth confirming if you haven't already.
    Cheers.
    jo proffi and Ron Boulton like this.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    2003 BA wagon LPG (For Sale)
