time out issues
Results 1 to 15 of 15
Thread: time out issues
    19,055
    Default time out issues
    I've had a couple of these today, plus the customry cloud flare graphic indicating AFserver is down.
    Af is also very slow for me at the moment. (15:09 23/11)
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,030
    Its been good here today.
    I was having net issues in general yesterday, everything seemed slow. I reset everything by powering down and then powering back up again and all come good.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    19,055
    All my "on site" problems completely have ceased since I chucked my el cheapo $30 ethernet switches and fitted a used Cisco SRW 2024 switch.
    The switch and my Telstra cable modem have not been down powered for around 6 months, since the UPS battery replacement.
    Best $100 I've spent for quite a while. I was really surprised the difference a commercial grade switch made to the network stability.
    Here is a bargain on ebay.
    http://www.ebay.com.au/itm/LINKSYS-C...IAAOSw5VFWNrb-
    The link seems a bit strange, but works if you hit "reload"
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,030
    That is a bargain Rob. The link worked first go for me.
    I'm only using a cheap switch but it seems to be fine.
    I think my issues were NBN related.
    Regards Col
    1973 Alpine A110
    19,055
    And it has s GBIC (gigabit interface converter) ports, which means, if the nbn modem has a fibre lan output it will plug into the router...
    Never run out of ports again..
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,030
    Yer there is lots of ports which is one thing that I have run out of.
    Regards Col
    1973 Alpine A110
    19,055
    Three pcs
    Sony TV
    Foxtel
    Two printers
    Video surveillance NAS
    Modem LAN
    ip cameras x 3
    I can account for 12 ports currently. And still have a lot of spares.
    If you need a switch, just buy it, you won't buy anything new as cheap (or as good). It also has Vlan (virtual lan) support and ip filtering and a host of other stuff built in.
    Worst case you will need to default it to factory settings. Which after you have done once is easy. And I have documented instructions.
    I also have discovered the (non standard) console lead connection details.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,030
    Will wait till I have to install more outlets around the house.
    If I buy that switch I will need to build a bigger box for all my gear to fit in, will wait till I really need it.
    Regards Col
    1973 Alpine A110
    19,055
    I just used an open top and bottom 8u rack frame, rather than a box. It's in a high cupboard in the centre of the house.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,030
    I don't have the space for one of those, they stick out from the wall to far.
    Regards Col
    1973 Alpine A110
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,182
    I am having trouble switching forums at the moment. Nothing happening when I want to revert back to the main menu. I just close down AF and start again going to the next forum.
    John
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,030
Name:	Cloudflare gateway.JPG
Name:	cloudflare error.JPG
    I had a similar thing just after midnight but seems to be all good now.
    Regards Col
    1973 Alpine A110
    19,055
    Around 300mm. Still too much ?
    LinkBasic 6RUWMOFP 6RU Wall Mount Open Frame Rack - Biggest Range and Best Price | Computers & Parts Land
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,030
    Yer still a little to far and not enough width where I have all my gear at present.
    Regards Col
    1973 Alpine A110
    19,055
    Pity, a wall rack makes for a tidy install. And is easy to "patch".
