Anyone have experience with this make/style of hoist? Makes my room more use-able.
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By seasink
  • 1 Post By seasink
Thread: Anyone have experience with this make/style of hoist? Makes my room more use-able.
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    Icon5 Anyone have experience with this make/style of hoist? Makes my room more use-able.
    Hero AutoHoists: Single-Post Parking / Display & Service Hoists
    Specifically the 3 tonne mechanics hoist.
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    8,682
    I wonder why the site makes so much of international standards, but not the ones that count-
    AS/NZS 1418.9 Cranes (including hoists & winches) Vehicle Hoists, and AS/NZS 2550.9 Cranes - Safe use - Vehicle Hoists.
    Jan 2015
    A comfy place.
    319
    Was thinking the same myself. And I will ask them.
    Gillian and Chris
    Oh, and a Holden.
    Jan 2015
    A comfy place.
    319
    Well, I'm now thinking of the portable 2.5 tonne one, which DOES have AS. Anyone have/used one of these?
    Gillian and Chris
    Oh, and a Holden.
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    749
    For my use I'd want to have it built into the floor not fitted later. Imagine the stress with a single post and the weight cantilevered (sp.) off that point - extra thick floor plus heavy bolts and plate set in when the floor is poured for mine!
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    8,682
    All that would achieve is to transfer the bending moment into a small area of slab. These hoists have steel "feet" under them that extend under the car beyond the load centre. The cantilever has a maximum moment at the post base, and the smallish live load of the car is spread at the supports. I'd be more concerned at the strength around that horizontal to vertical joint.
    Deflection under load is mentioned in the Standard. There was a nasty accident where a vehicle fell when the swinging load arms slipped - the rubber pads apparently weren't in use.
    Lasya likes this.
    19,049
    I thought that too. I expected see some substantial gussets at the base to post intersection and also a much larger base area to allow better fixing to the slab.
    Banned
    sydney, australia
    11,301
    jesus all its holding is a couple of tonnes of car.
    i would think 8 presumably high tensile bolts would be enough to hold the vertical to the horizontal without falling over.
    IWS
    IWS is online now
    1000+ Posts IWS's Avatar
    Feb 2005
    Hawthorn East, Vic.
    1,306
    I'm not an engineer - but I'd reckon it is a little more complex than that. Physics of leverage and all that.
    I'd certainly not be getting under " a couple of tonnes of car" with just 8 bolts connecting the hoist to the floor!
    Ian.
    8,395
    Quote Originally Posted by IWS View Post
    Ian.
    Thank goodness for real engineers then. (as opposed to those 'experts' with a google degree in everything, ).
    Jo
    8,682
    I tried to explain the problem, I thought. The floor fixings provide mainly lateral restraint. The aim is NOT to put large stresses in the floor, which is unlikely to be designed to suit in the best workshops.
    The base geometry is to make bending within the structure, and the resulting magnitude of deflection, the design criterion, rather than slab stresses. The AS mentions this.
    addo likes this.
    IWS
    IWS is online now
    Feb 2005
    Hawthorn East, Vic.
    1,306
    So as I said, I'm not an engineer and Jo, I did not pretend to be "expert" in this matter. Excuse my ignorance above. Your explanation seasink seems to explain - to a lay person - why the design of this thing could be safe. Interesting.
    Ia.
    16,370
    Why don't you look for a used 4poster .... That way you don't need to worry so much about the slab
    Jan 2015
    A comfy place.
    319
    "Apparently" the slab is not much of a problem. It has a large enough surface are to distribute the weight...
    Gillian and Chris
    Oh, and a Holden.
    Jul 2003
    Glen Waverley Victoria
    498
    Quote Originally Posted by Lasya View Post
    The problem as I see it is that you are not distributing the weight. The weight is only distributed over the relatively small area of the base.
    My fix would be to lay down a decent slab of 19mm plate,like they use on roads, tie that to the floor then mount the hoist to that using some substantial metal thread bolts.
    Those people that say I know - generally don't.
