Regassing sphere's
    16,370
    Default Regassing sphere's
    Hi guys,
    check this out, they are the sphere fitted to our Xantia. Looks like Citroen is trying to be @ssholes and prevent sphere regassing (forcing you to buy new ones).
    look at the bloody dimples they have put around the filler plug, so regassing equipment can't get a seal
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Shane,
    I've heard about this before & it's apparently no big drama.
    Among things available are valves that just screw straight in. The gear a guy I know has it would have no effect on.
    May be worth asking Jon Wood's opinion as I know they've struck it over there.
    Alan S
    NSW
    4,917
    this message should be in the citroen forum really........
    16,370
    Hi Alan,
    yeah, David Cavanagh reckons he can gas them (his regasser must have a bigger sealing cup, so it seals beyond the dimples.
    I usually get Kirk to regass my sphere's, however he can't do these Xantia spheres. He said he tried it once, and when he hit 600psi the seal blew out. To put it his way "sh!t flowed freely" when the seal blew out
    CitroŽn Tragic UFO's Avatar
    9,700
    Here in always wise NSW, the gassing kings use an extra O ring over the nut with about 1mm clearance between the ring and the nut. This ring then sits inside the "pressure head" and does not interfere with the main seal on the head. Through the mysteries of physics it then helps to seal the whole lot.
    The only downside is that it takes a little longer to gas the sphere, particularly if they are high pressure accumulators and the like.
    I would imagine the rig Kirk has would be pretty similar to the NSW ones.
    And yes, this thread should be in the Cit forum, someone???
