Three pot engines
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By gerry freed
  • 1 Post By Uffee
Thread: Three pot engines
    8,695
    Default Three pot engines
    Interesting article on the PSA 3 cylinder turbo engines that are replacing the 1.6 4 cyl naturally aspirated engines.
    Features - Automotive Engineer
    Like the cars, the engines are getting more complex.
    Jul 2014
    rye
    32
    SAAB had a 3 pot 2stroke not a bad car but it had its problems.
    Tony
    3,523
    Very handy for a quick getaway, as nobody can see which way you went in the smoke screen that you are laying down.
    .2010 Holden Commodore Ute
    Jul 2013
    Metung, Victoria.
    65
    Most of the problems besting the SAAB two stroke triple have been addressed by Evinrude in their E-Tec engines for boats and snowmobiles.
    Expect to see a return of direct-injected two strokes.
    The one area that they have inherent superiority is in lower Oxides of Nitrogen levels produced.
    Watch this space.....
    Jun 2003
    Lauderdale, Tasmania
    2,887
    We first met a 3 pot engine in Yo's Daihatsu Cuore, 15 years ago. It was a very smooth economical little unit.
    That article leads me to point out again the difficulty of occasional or recreational mechanics working on modern engines. You can't take a "she'll be right attitude with the torques around the block and head" or attempt any replacements around the cylinder bore/piston/ring territory. How about an assembly mistake on a turbo whose rotor is thinking of spinning at 270,000rpm?
    Fortunately these modern engines outlast the car, thanks to recycled plastics and so engine recons are a thing of the past. If it breaks - chuck it.
    almostfrench likes this.
    8,695
    It's as well then they last Gerry. Most dealerships have no more in the way of engine tooling than I do.
    Though it's now a long time since things like my ring compressors got much work. I haven't used the exhaust gas sniffer in a decade I think. There's a large shelf full of tools and equipment unused but too good to discard - a bit like owning old cars I suppose.
    19,055
    Quote Originally Posted by 27of85 View Post
    Modern two stokes run 50:1 petrol : oil. That 20ml oil per litre of fuel.
    I use the 50:1 Stihl line trimmer mix in the 4 stroke mower.
    I've never seen the "smoke screen" you talk about.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,965
    Two strokes do not need petrol and oil (petroil)mixed for lubrication. The GM engine featured in a resto thread here recently is a two stroke but runs a conventional pressure lubrication system. Any modern two stroke will do the same to reduce pollution.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,752
    Quote Originally Posted by Kim Luck View Post
    Is that the "GM" engine that was developed by Orbital in Perth using their proprietary direct injection system, bought by GM and then shelved? It was a cracker of an engine.
    8,695
    No, the resto thread showed an old Detroit Diesel. A General Motors concern back then, but Daimler today.
    Melbourne, Aus.
    17,965
    As per Seasink's reply, except Sarich's fuel injection system from the Orbital engine was licenced to Mercury outboards and other manufacturers and I believe it is is still current.
    May 2002
    canberra...
    8,752
    Righto. I've seen the 2 litre inline 6 cylinder 2 stroke wet sump direct injection motor they built on a stand, from all accounts it was a honey to drive. I remember them selling the rights but it never went anywhere.
    Orbital are still sort of surviving off their licensing deals, but they do lots of cool stuff too. Alas they may not survive the globalisation of the car industry.
    651
    Interesting article on the PSA 3 cylinder turbo engines...
    1.4 bar boost, 200 bar multiple injection, the distinction between petrols and diesels is continually erroding.
    504 GL Coupe '73 Silver
    407 HDi Sedan '05
    19,055
    Quote Originally Posted by Uffee View Post
    They are already exceeding.....
    651
    I didn't mean from a performance point of view, petrol should always be in front given the richest a diesel can run is around 18:1 whereas a petrol is 14:1.
    I meant 'architecturally'. Eg:
    - Compression ratios for diesels are coming down whilst petrols are going up. You can have a ferrari with 13.5:1 whilst Toyota have a diesel in development with a ratio of 14:1.
    - Petrols are moving towards high pressure direct injection (this is the first time I've heard of multiple injections)
    - Petrols being extensively turbocharged.
    - In this specific case, the materials engineering is being inherited from what's in the diesels.
    Kim Luck likes this.
    407 HDi Sedan '05
