405 mi16 gear linkage bush
  • 1 Post By pgti6
Thread: 405 mi16 gear linkage bush
    Mar 2014
    104
    Default 405 mi16 gear linkage bush
    Hi All,
    What are people doing to replace OEM part which is no longer available?
    2449 74
    NFP
    01
    GEARSHIFT CONTROL RETURN
    My rubber round bush that sits over the plastic 'ball' on the shaft is stuffed (circled in red). Do I just get a block of rubber, mill out the insides and push that over the plastic ball which when pushes into the metal bracket on the gearbox connection shaft?
    Geoff
    Attached Thumbnails Attached Thumbnails 405 mi16 gear linkage bush-405mi16gearbox-linkages.jpg
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    You can buy that rubber ball fitting from EAI.
    Attached Thumbnails Attached Thumbnails 405 mi16 gear linkage bush-405-gear-change-ball.jpg
    mi16pug likes this.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Mar 2014
    104
    Great. Is the part number the oem one?
    May 2001
    1,612
    Yes, they use oem part numbers there.
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Mar 2014
    104
    Quote Originally Posted by pgti6 View Post
    Dilemma - your old linkage (and the new linkage) shows the ball joint in the first hole and the new part (part 244973) is in the same place. You must have a BE1 gearbox?
    The linkage I took out from my car has the ball joint at the end of the selector - this is OEM part 244974 - for the XU and BE3.
    EAI has not had the BE3/XU linkage bracket in before.
    BE1:
    BE3:
    May 2001
    1,612
    Nope BE3.
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
