Common problems & fixes
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By addo
  • 1 Post By GreenBlood
Thread: Common problems & fixes
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,332
    Icon2 Common problems & fixes
    Mods...any chance we can have a sticky so C5 faults/cause's can be on one thread... then it would be easier to research your C5's problems....
    IE
    2004 ...2 litre hdi auto...VIN ***
    issue
    anti pollution & esp/asr warning lights
    possible cause
    Brake switch,EGR valve,MAF,swirl valve actuator,fuel filter,vacumn lines & T piece cracked?
    etc etc
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1970 DS21 Cabrio replica
    Citroen 1966 ID Safari (with 23 running gear)
    Citroen 1975 DS23 Safari
    1975 VW Kombi poptop
    1987 2CV
    Porsche Boxster S manual
    1988 Vespa PX200E
    8,176
    Icon3
    Quote Originally Posted by dogboy View Post
    IE
    issue
    possible cause
    etc etc
    You can search the entire forum using Google Search in the top right hand corner
    08 C5 X7 HDi very Noir
    8,690
    And there's more than 1 model C5, with quite different engines and systems.
    Google would give better results if posters would mention which model.
    1,332
    true...and that is at the heart of the problem....google is fine but it's confusing to sort out the relevant info and I found myself reading similar posts or ones that didn't relate to my model...thought a sticky would make it a lot easier...just a thought
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    8,176
    Icon5
    How would that work??
    You would need a sub forum, with the full range of C5 models listed.
    Many of the problems cross over from model to model and indeed Peugeot to Citroen.
    Then the question, why just C5???
    Let me know how you would make a 'Sticky' work and it will be considered.
    Fellow Frogger! John P's Avatar
    Somerville, Victoria
    153
    How about a thread title such as "C5 issues" and a request that posters identify their model in the heading of their individual posts? I see the flaws, but it is simple and at least a place to start. A comprehensive and flawless system would be just about unworkable, I think.
    2006 C5 2.0 HDI estate - daily driver
    1981 2CV - The Amelie project is complete.
    1930 C6F torpedo - My Great Folly! Project under way.
    8,176
    Quote Originally Posted by John P View Post
    We have an archive of 'Common Faults and Fixes' that is under subscribed and utilised, the intent was/is very much as you describe.
    Archive / Common Faults & Fixes
    You need to set 'Display options' to 'Beginning' there is a huge under utilised resource already set up.
    Don't remind me!
    16,609
    I still maintain many of these issues can be resolved by rolling the hardware back a version or two.
    GreenBlood likes this.
    Feb 2011
    brisbane Au
    927
    Sadly, after seeking forum help, very few bloggers re-post when the problem is fixed, so any "Sticky" would risk becoming just a dated list of problem inquiries, as it is at present on most forums, with very limited posts of any successful results.
    1,332
    I don't see it as a thread where your problem is posted..rather a thread just on C5 issues & fix's
    any post is to give the issue and rectification or range of possibilitys to investigate...
    that way anyone with any model C5 can read the thread and see what applies to them....currently you search the forum...get a range of stuff to read...half of which is not relevant
    In fact...it doesn't have to be a sticky
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    8,176
    What you describe fits the purpose of 'Archived Common Faults and Fixes' perfectly.
    That forum, as I think you may have discovered is moderated, any threads started have to be approved by the forum moderators. This prevents useless/incorrect information being archived, I believe there are no replies permitted for the same reason. The information archived should be factual and correct.
    For it to work the thread title needs to be brief but relevant to the detail i.e 'Citroen C5 Series 1 Fault codes'
    It would then be easy to scroll through the forum titles, in this case Citroen/ C5/ Series/ problem/fix
    Threads that have been started in the main forums can, and have been copied into 'Archives Common Faults and Fixes' Re-Titled to suit the format. As I have mentioned this is an oft forgotten resource that could use a spring clean and be better utilised.
    Feedback from members that have received good advice is invaluable, if a fix is established to be correct the ACFF moderators can be made aware and copy the relevant thread (or post(s) within a thread) to the archive.
    Does this sound more like the solution you seek?
    Edit: As this is relevant to the whole AF community I would (with your permission) like to re-title this thread and move it to 'Froggy Chat'. We may get a little more pertinent input before any changes take place.
    ScotFrog likes this.
    1,332
    cheers Chris
    That does fit the bill...
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
