Alloy rims for a Peugeot Partner/ Citroen Berlingo
    Jun 2011
    Flinders Island Tasmania
    96
    Default Alloy rims for a Peugeot Partner/ Citroen Berlingo
    Hi fellow froggers,
    Just wondering what original Peugeot/Citroen 15 "alloy rims wil fit my 2010 Peugeot Partner, does anyone have any ideas ?
    tweed heads
    1,484
    Default Alloys
    Quote Originally Posted by furneauxfrogger View Post
    hi fellow froggers,
    just wondering what original peugeot/citroen 15 "alloy rims wil fit my 2010 peugeot partner, does anyone have any ideas ?
    i have fitted a set of peugeot 405 mi 16 ,15 inch alloys on a second series berlingo[side sliding door],they fitted ok but the rears rubbed on the inner rear guard ,stud pattern the same ,i dont know that they will clear your brake calipers ,pugs
    Don't remind me!
    16,609
    Your stock wheel is 6J◊15, 27mm offset. The factory 16" rim is 26mm offset, same width.
    307 wheels in 15 inch will fit like-for-like. The 16" wheels off a 307 have a deeper offset and you'd need a 3-4mm spacer.
    The same goes for earlier 308s with the 4-bolt wheels.
    You could also look at the CitroŽn C4 as from memory it shares wheel offsets with the 307.
    Jun 2011
    96
    Thanks for the info, much appreciated !
