Retro fitting Reversing Cam to 2013 Koleos Factory Headset
Results 1 to 8 of 8
    Tadpole mudsam's Avatar
    Jan 2014
    Queensland
    2
    Default Retro fitting Reversing Cam to 2013 Koleos Factory Headset
    I have a 2013 Koleos Bose Edition but unfortunately it doesn't have a reserving camera fitted in this model. I've been searching the net to find out how easy it would be to retro fit a camera to the existing GPS display. Do I need to upgrade the headset or is it just plug and play? Maybe it requires a software update to handle a camera? Does anyone know how to go about it?
    Fellow Frogger! DanielBendigo's Avatar
    Mar 2012
    Bendigo
    660
    Does the GPS unit have an auxilary input on the back at all? If it does, you can just plug it into that, as most of them just plug into the auxillary (I've been looking myself lately). But I'm not sure if they automatically switch to the camera when you go into reverse.
    Jan 2014
    Queensland
    2
    Not sure if it does have an auxilary input as I haven't pulled it apart yet. Hopefullly someone else might be able to help us both.
    Fellow Frogger! Covert's Avatar
    Covert
    449
    Default Renault Koleos 2014, Reverse Camera on Factory Display
    Quote Originally Posted by mudsam View Post
    I remembered this thread from ages ago and came across this website... maybe of interest
    Renault Koleos 2014, Reverse Camera on Factory Display | Maroochy Car Sound
    Feb 2012
    2
    Did you ever find an answer to this. I'm trying to find someone to do it without success so far
    19,218
    Quote Originally Posted by Renno #9 View Post
    You could try this company: Automotive Integration Prestige & Performance Vehicle Electronics
    I haven't used them personally, but they sorted a friends BMW and he was very happy with the work.
    1000+ Posts driven's Avatar
    Apr 2005
    1,570
    Once again as good as many
    https://www.youtube.com/watch?v=rVOqwalEwNQ
    and even better still is to jailbreak Renault software. It uses modified Microsoft windows
    WARNING Tread carefully
    https://www.youtube.com/watch?v=V3PMRciEthg
    Any modern Renault can be retrofitted with reverse camera.
    The wires are there already just need a camera easy just $40 from Europe
    https://www.ebay.com.au/itm/Rückfahr...53.m1438.l2649
    19,218
    I've been through this situation on other vehicles with Windows Ce (aka windows embedded)
    The problem is finding an input device to port the reversing camera composite video to the operating system.
    It depends if the head unit that you are hacking has video input hardware inbuilt and if that hardware is supported when the OS is hacked.
    It can be nightmare or simply not possible to get a reversing camera to display on an OEM screen.
    Of course you may find the reverse camera input is already on the head unit. And just needs to enabled via the dealer software.
    If you buy a reversing camera make sure you know the video standard that Head unit accepts. Two standards are widely in use PAL and NTSC.
    Some head units are accept either and switch automatically.
