Xantia Diesel 5th Gear Problem
Results 1 to 9 of 9
    Nov 2013
    4
    Default Xantia Diesel 5th Gear Problem
    My Diesel Xantia has been jumping out of 5th gear and having excluded other possabilities, I am fairly sure I need to replace the synchromesh hub. According to info on the net, this seems to be fairly straightforward job, but I need to obtain a replacement!
    Does anyone know if the 5th gear Synchromesh hub is the same on all BE3 gearboxes?
    Any ideas on sourcing one in Australia would be appreciated, I would also consider a scrap Xantia.
    many thanks.
    mike.
    Coffs Harbour, NSW, Australia
    626
    Is that the same box as fitted to the standard 2Ltr Xantia ? If so I will be scrapping my old one soon & the box is great, not so the clutch or motor.
    Richard....Coffs Harbour.
    Nov 2013
    4
    Hi Richard,
    That is what I'm hoping someone might know, acquiring a donor car with other useful parts would be good and if it doesn't cost a fortune to transport, I'd take a gamble on it.
    mike
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,350
    The ratio's will be different. The diesel has a lot more low down power so will be geared lower.
    Via the aussiefrogs App
    2017 Renault Koleos auto
    Nov 2013
    4
    I'm sure you are correct, and swapping the whole gearbox would doubtless not be a good idea, but I wonder if all the gears in the box are different or maybe just the crownwheel is changed?
    Don't remind me!
    16,609
    The gearboxes have a sub-classification, I think they are 5L2, 5N2, 5V2. With that, you can identify which gears are in it.
    626
    The 'box in the Turbo CT is different, so I suspect the diesel with it's extra torque may use the same one.
    Richard
    tweed heads
    1,544
    Default Same box
    as in PUG 405 SRDT ,5TH GEAR IS LOCATED IN THE END COVER ,SO CAN BE REMOVED WITH G/BOX IN CAR ,I HAD AN SRI WITH THESE SYMPTOMS ,JUMPING OUT OF 5TH ,THE NUT THAT HELD THE 5TH GEAR HUB ONTO THE MAIN SHAFT HAD COME LOOSE ,IT EVENTUALY STRIPED THE SPLINE ON THE MAIN SHAFT ,IF I HAD KNOWN WHAT WAS CAUSING THE PROBLEM ,I COULD HAVE SAVED THE BOX ,I WOULD BE CHECKING THAT OUT BEFORE I WENT ANYWHERE WITH A REPLACEMENT BOX. PUGS
    tweed heads
    1,544
    there was a post a while back same problem with a Berlingo ,he replaced with new parts, gearbox still in car, PUGS
