Dspecial restoration 1975
Page 1 of 10 12345 ... Last
Results 1 to 25 of 248
Like Tree264Likes
Thread: Dspecial restoration 1975
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    Default Dspecial restoration 1975
    The work has begun there is lots to do and good second hand panels to seek. I managed to find a roof without sun roof and a reasonable roof rail and still need a boot and passenger doors front and back. Please let me know if you have any parts. My new steering wheel has finally arrived More to come
ID:	89492Click image for larger version.
ID:	89493Click image for larger version.
ID:	89494Click image for larger version.
ID:	89495Click image for larger version.
ID:	89496Click image for larger version.
    Guildford West
    359
    A few more pics the engine is ready to go back with new clutch kit new timing chain new recon head new alternator new starter motor, new water pump and cylinder compression tested between 160 and 165psi so no rebuild. brake calipers rebuild including hand brake system. Suspension cylinders fitted with new rubber and Teflon kits.
    The roof rail above the front windscreen is rusted pretty bad and this weekend the roof will come of possibly revealing more nasties
    the lower section of the chassis is basically rust free. Luckily the harnesses is acceptable.
ID:	89498Click image for larger version.
ID:	89499Click image for larger version.
ID:	89500Click image for larger version.
    Bounge likes this.
    Apr 2016
    Bedford, UK
    657
    Looks like it's well underway! looking forward to following your progress.
    Guildford West
    359
    No worries Budge as I mentioned above this resto has a bit of body rust and I just wish I could weld... I will certainly take more pictures as I go along
    Guildford West
    359
    Ok 5 vintage retro tyres received, Some items painted and beleive me more to come, drive shafts degreased and in quite good condition ready for new rubber boots to be fitted. this weekend roof removal to investigate condition of the roof rail.
    Attached Thumbnails Attached Thumbnails Dspecial restoration 1975-20160930_064622.jpg   Dspecial restoration 1975-20160930_064558.jpg   Dspecial restoration 1975-20160930_064532.jpg   Dspecial restoration 1975-20160930_064506.jpg   Dspecial restoration 1975-20160930_064458.jpg
    59 Floride and Bounge like this.
    Ici.
    2,485
    I feel for you Phillipe! You're no slouch though!
    Guildford West
    359
    No just crazy!!! I dont know why Ive started another
    Guildford West
    359
    Some nasties will deal with this next!! lets get the engine started first....
ID:	89696Click image for larger version.
ID:	89697Click image for larger version.
    Guildford West
    359
    Well lets get the engine started first. this is a 1969 motor and gear box assembly and the car is a 1975 model a few issues had to be sorted as im going along.
ID:	89699Click image for larger version.
ID:	89700Click image for larger version.
ID:	89701Click image for larger version.
ID:	89702Click image for larger version.
    Lasya likes this.
    Guildford West
    359
    Busy weekend
ID:	89709Click image for larger version.
ID:	89714Click image for larger version.
ID:	89710Click image for larger version.
ID:	89711Click image for larger version.
ID:	89712Click image for larger version.
    GreenBlood, JohnW, Lasya and 1 others like this.
    10,677
    That roof rail looks truly horrible.
    I was interested in the shelf on the back wall to see what you had stocked up there, but it is out of focus... Always interesting to see what folk keep on their shelves..
    Good luck with the steelwork. Engine etc look just lovely.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Guildford West
    359
    Just junk!! working in my sons garage which is quite confined .
    10,677
    Quote Originally Posted by Le Parisian View Post
    Very funny! Thanks....
    Renault 4CV 1951
    Renault R8 1965
    Guildford West
    359
    Default 1975 DS special restoration
    A bit more work done on the weekend
    the alternator fitted is a 75Amp with internal regulator I only use this model in my restorations and buy them from citroworld. Installation is simple only 12 Volt supply and light to dash light wires are required you can then tie up the remainig 6 wires from the old external regulator and Voila Done!!
ID:	89820Click image for larger version.
ID:	89821Click image for larger version.
ID:	89822Click image for larger version.
ID:	89823Click image for larger version.
ID:	89824Click image for larger version.
ID:	89825Click image for larger version.
    ajaxvte and forumnoreason like this.
    Guildford West
    359
    And a few more
    The spheres diaghrams are new and once in this will complete the hydraulic circuit.
    Taking a chance with the steering rack, just tidied up and refit it wasn’t leaking prior restoration and if it does then bugger
ID:	89827Click image for larger version.
ID:	89829Click image for larger version.
ID:	89830Click image for larger version.
ID:	89831Click image for larger version.
ID:	89832Click image for larger version.
ID:	89833Click image for larger version.
ID:	89834Click image for larger version.
    ajaxvte, 59 Floride and ds21bvh like this.
    Guildford West
    359
    Default 1975 Dspecial resto
    Remarkably this chassis is quite rust free apart from the roof rail section above the windscreen the boot area looks almost like new
ID:	89855Click image for larger version.
ID:	89857Click image for larger version.
ID:	89859Click image for larger version.
    Guildford West
    359
    The dash will come good after a good clean. Actually I need to remove it to repair the rust on A pillars
ID:	89868Click image for larger version.
ID:	89870Click image for larger version.
ID:	89872Click image for larger version.
    Guildford West
    359
    Another batch of goodies from Citroservices including more fiddly bits
ID:	89893Click image for larger version.
ID:	89894Click image for larger version.
ID:	89895Click image for larger version.
ID:	89896Click image for larger version.
    Perth Western Australia
    2,660
    Le Parisian,
    I feel sorry for that little Solex [34mm ?] having to cope with everything.
    Oh, do everyone out here a favour and reposition that fuel filter to the tank side of the fuel pump. Suction not pressure.
    Guildford West
    359
    Le Parisian,
    Agreed not happy using the small Solex carburettor, perhaps if you have a spare Webber kit let me know?? I temporarily fitted the carby with the filter in that position as per previous owner did to close the fuel circuit; the tank is being worked on and a new filter will need to be purchased and then I will consider fitting it to the tank side also thinking about fitting an electric pump. You get 10 points for good observation
    Anything else wrong???
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    367
    Default D Special restoration 1975
    loving this Phillip you guys seem to have down to a production line. impressive and very fast. the experience is showing as it is the attention to detail that is importance. especially as these cars have so so many damn bits and pieces. it is also good that repo parts are available.
    congratulation look forward to seeing the finished product.
    Bounge likes this.
    9,628
    Has the quality of repro rubber improved recently? Some of it has been terrible going back over the last several years. I bought a mudflap kit with those stainless fittings from one of the usual suspects and the rubber stank so much it couldn't stay indoors. Are these OK? Some mudflaps bought via CTA were in contrast very much better.
    That filter is where almost every car you will encounter has had it fitted. It may not be strictly correct, but that's where it usually is. Isn't there supposed to be strainer in the tank in the form of stacked discs? The EFI cars have a filter located in the sill between the tank and pump, but you don't have that in a carby car. EFI fuel tanks don't get the strainer per the parts book. There's a document covering it in the downloadable parts/manual info. Look for "DS fuel tank filter.pdf" in the fuel-system directory of the Green CD.
    Apr 2016
    Bedford, UK
    657
    Great to see your progress. very inspiring. Having viewed several days posts in one evening it all makes it look so quick and easy!
    Guildford West
    359
    Quote Originally Posted by lamoor View Post
    Thanks for the compliments Lamoor its still a long way to go but we are enjoying ourselves my son and I that is.
    Repro parts are not ideal and they are expensive but I least you have something that you can use.
    Guildford West
    359
    Well!! I would say the rubber flap kit is not too bad I bought it from Citro Services and I must say the smell is tolerable you’re right some years back it really smelled.
    Correct!! Most fuel filters that I have seen have been fitted pass the pump the location is really irrelevant the pressure of the mechanical pump is actually quite good and the filter is passive with very little drag. You will know quickly if any issues.
    Right or wrong this is my 2 cents worth.
