Dspecial restoration 1975 - Page 5
Page 5 of 10 First 123456789 ... Last
Results 101 to 125 of 248
Like Tree264Likes
Thread: Dspecial restoration 1975
  1. #101
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    357
    Default Dspecial restoration
    Despite the 40 degree yesterday evening I was determinate to fit the new windscreen. I purchased an aftermarket rubber seal, well let me tell you it’s nothing like the original rubber what a bastard to fit my fingers are still aching it took 3 of us and lots of patience to complete the job. The old rubber being 40 years old couldn’t be used again.
ID:	91908Click image for larger version.
ID:	91909Click image for larger version.
ID:	91910Click image for larger version.
ID:	91911Click image for larger version.
ID:	91912Click image for larger version.
    GreenBlood and Bounge like this.
  2. #102
    8,103
    Quote Originally Posted by Le Parisian View Post
    You did well, perhaps having a 40 degree day actually helped. I had the same trouble with mine and ended up taping the rubber in position and left it for a couple of weeks to take on the shape required - especially the tight curves.
    08 C5 X7 HDi very Noir
  3. #103
    Guildford West
    357
    We still used duct tape to hold the rubber in place I remember reading this from someone on Aussiefrogs, also one of my friend’s hands are like a vice and that helped a lot!!!! He can run his finger under the rubber edge to pull it over the channel….
    I left the rubber around the windscreen for a few day I guess that also help….
    I’m also convinced that the aftermarket windscreen isn’t the same size as the original believe me it’s not the perfect fit but still acceptable no other choice
  4. #104
    Ici.
    2,408
    Philipe you were looking for one of these?
    CITROEN Platine / Boutons Pour DS
  5. #105
    Apr 2016
    Bedford, UK
    608
    Are you taking off grey but replacing with black? I used to have an ID19B that didn't have laminated glass. The screen was thinner and needed a black windscreen rubber. I think laminated screens are thicker and need the grey rubber.
  6. #106
    Guildford West
    357
    Actually Chris was kind enough to provide some of the missing bits
  7. #107
    Guildford West
    357
    Im using the grey rubber aftermarket crap
  8. #108
    Guildford West
    357
    Icon11 1975 DSpecial restoration
    Back from Holiday and back into it, its bloody hot and not easy to restart anyway the back parcel and rear window now completed, Black carpet obtained from bunning and foam material under carpet
ID:	92671Click image for larger version.
ID:	92672Click image for larger version.
ID:	92673Click image for larger version.
ID:	92674Click image for larger version.
ID:	92675Click image for larger version.
    gsowner84 likes this.
  9. #109
    8,103
    Icon3
    Hi Phillipe and Happy New Year
    This may interest you and possibly a few members here, Citrotech in the Netherlands can now supply reproductions of clocks for early and late Ds - these have a digital movement and will be far more reliable than the OEM Jaeger clocks. They look to be very good copies, only lacking the 'Jaeger' made in France.
    Klokje DS ?68-> **nieuw!!** ? CITROTECH
    Attached Thumbnails Attached Thumbnails Dspecial restoration 1975-d-clock.jpg   Dspecial restoration 1975-d-clock-early.jpg
  10. #110
    Guildford West
    357
    Hi Chris
    Happy new year to you as well as your family
    I must have one of these clocks Thanks for the tip
    Bounge and ds21bvh like this.
  11. #111
    Guildford West
    357
    Default DSpecial restoration
    the dash is complete with all small details added will fit the new steering at the end too much glare for descent pictures
ID:	92679Click image for larger version.
ID:	92680Click image for larger version.
  12. #112
    Guildford West
    357
    Default Citroen Dspecial resto
    Its getting too hot so no more work for today. I have a pallas roof lining kit actually it come with the car I have lined up a mobile roof liner guy for Friday cant wait! so I can look up and see pallas and then look down and come back to reality. I will clean and leave the vinyl on the floor and fit new sealing rubbers not easy to remove these bloody screws holding the stainless trims.
ID:	92686Click image for larger version.
ID:	92687Click image for larger version.
ID:	92688Click image for larger version.
ID:	92689Click image for larger version.
ID:	92690Click image for larger version.
ID:	92691Click image for larger version.
    Bounge likes this.
  13. #113
    Guildford West
    357
    Default Citroen dspecial resto
    I picked up my carpets today from Siba motor trimmer Lansvale (total cost $180.00 with thick insulation) and since he did a reasonably good job decided to drop my seat inserts as well as all the seats for Siba to recover, should be ready in 2 weeks also cleaned the grey vinyl and replaced the lower rubber seals
    Attached Thumbnails Attached Thumbnails Dspecial restoration 1975-20170111_104850.jpg   Dspecial restoration 1975-20170111_104900.jpg   Dspecial restoration 1975-20170111_130332.jpg   Dspecial restoration 1975-20170111_151045.jpg   Dspecial restoration 1975-20170111_151053.jpg   Dspecial restoration 1975-20170111_151100.jpg
    Dspecial restoration 1975-20170111_104927.jpg   Dspecial restoration 1975-20170111_104931.jpg   Dspecial restoration 1975-20170111_104942.jpg   Dspecial restoration 1975-20170111_104958.jpg   Dspecial restoration 1975-20170111_105006.jpg   Dspecial restoration 1975-20170109_082115.jpg
  14. #114
    Ici.
    2,408
    Looking great Philipe and pleased to see I'm not the only one copping heat to work on cars! I wanted to ask you what you're doing with your old seat covers, I need some that style for patterns in stitching to use as templates for a guy I want to do mine, even the back white bits would be handy if you' re not using them, Cheers Steven
    ps those mats look the goods btw!
  15. #115
    Guildford West
    357
    Hi
    As you can see on the pictures the seat covers are quite thin and worn especially the front driver seat anyway I will see if the upholsterer has kept them not sure what you mean in regards to back white bits??
  16. #116
    Guildford West
    357
    Default Citroen Dspecial restoration
    This weekend the roof liner has been fitted and I’m not too impressed with the work! Wouldn’t ask this guy to do another, as mentioned before I used the liner that come with the car and “no” it’s not a Dspecial liner more like a Pallas grey velour with 6mm foam Well it doesn’t look too bad. On another note I finally found the reason why the nose of the car kept going up and down the culprit was the left front suspension cylinder it had a huge leak and kept filling the rubber boot and excessive LHM kept going back to tank now replaced with a good 2nd hand cylinder. Never seen this fault before and now the cycle time exceeds a minute. Also fitted the 123 Electronic ignition I must say “WOW” what a difference and finally adjusted all tappets. The engine sounds really sweet.
ID:	92950Click image for larger version.
ID:	92951Click image for larger version.
ID:	92952Click image for larger version.
ID:	92953Click image for larger version.
    forumnoreason and Bounge like this.
  17. #117
    654
    Very nice.... but no 69 version...?
    LOL 8-D...
    Someone had to say it....
    Keep up the great work Phil - your keeping me motivated...
    Mark...
  18. #118
    Ici.
    2,408
    I was referring to the white vinyl backing 'board' on the rears of the front seats, I could use those if you're doing targa and chucking them. NO!!! I hope he has kept them and the seat covers as they would be great to get the measurements off. Fingers crossed!
    Also is that holding stay off the water pump for the speedo cable an original piece? I have wondering about the way mine just 'floats' around.
    PLUS I see you've attached the earth down below on the water pump, is that a factory locarion for them?
  19. #119
    Guildford West
    357
    Quote Originally Posted by ds21bvh View Post
    LOL 8-D...
    Mark...
    Hi Mark
    My clock requirement is for a 1975 Dspecial just simplicity I guess!! Are you chasing another 1969 model??
    Thanks god I’m near completion can’t wait for the panels to go back on the car possibly within the next 4 weeks, thanks for the compliment Mark I wish someone would keep me motivated
  20. #120
    Guildford West
    357
    Well sorry but the old white bits have been picked up by the Garbo truck on the weekend and by the way you don’t need a template for these bits just cut the material roughly around, glue and tuck under that’s how the guy did the job. I regards to the seat covers I will check when I pick the seats up.
    I believe its an original support for the speedo cable I have seen them before you can get similar clamps lined with rubber at super cheap I do use them doesn’t have to be an original Citroen version as long as it does the job.
    The main earth is usually connected to the water pump as I have seen in the past many times
  21. #121
    Ici.
    2,408
    Bummer Philipe wish I'd got onto you earlier about the seat backs. What I want to check on the seat covers is the measurements for the stitching on the seat itself not the shape as such, where the padding has rows and is raised with stitching on seat both where you sit and the front of the seat where your back rest, the squarish bits in the middle of each section if that makes sense. same for the rear.
  22. #122
    Guildford West
    357
    Refer to page 2 and 3 where the seat material patern is exposed you will discover that my seats front and back had no stiching at all and the material was of poor quality and very thin.
  23. #123
    Ici.
    2,408
    ok then, thought I could see it : )
  24. #124
    Guildford West
    357
    Default 1975 citroen Dspecial
    Just received pictures from the upholstery guy, the seats can be picked up on Friday looking good......
    The Car will be tranfered to the panel beater within the next 2 weeks its time to dress her up with a lovely new dress
ID:	93242Click image for larger version.
    Boyracer, Bounge, Lasya and 2 others like this.
  25. #125
    Guildford West
    357
    Another hot weekend, what can you do just have to persist with it!!!!
    Anyways here is a few more pics I would say the car is now ready and waiting on the panels.
    Next I need retractable seats belts for the front seats and also must organise new windscreen wipers
ID:	93404Click image for larger version.
ID:	93413Click image for larger version.
ID:	93412Click image for larger version.
ID:	93411Click image for larger version.
ID:	93410Click image for larger version.
ID:	93409Click image for larger version.
ID:	93408Click image for larger version.
ID:	93407Click image for larger version.
ID:	93406Click image for larger version.
ID:	93405Click image for larger version.
