Dspecial restoration 1975 - Page 3
Page 3 of 10 First 1234567 ... Last
Results 51 to 75 of 248
Like Tree264Likes
Thread: Dspecial restoration 1975
  1. #51
    SWOTR
    3,313
    Terrific result and a great looking car. Well done.
  2. #52
    10,381
    Thanks to all. Most kind. I really didn't want to hijack the thread, just to respond to the soda blast question....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  3. #53
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    357
    Thank you so much. We had a big family debate about the colour. I wanted to go to her original grey (they look lovely in grey) but she'd been blue since 1966 (yes, I've owned the car for 50 years now) and I was outvoted. I'm not unhappy with the results though! The surprise was just how good the metal was under the awful paint.
    And to repeat, the soda blasting really was very satisfactory.
    In my opinion I call this colour the perfect blue, "50 years" cant believe you kept this car for so long....
  4. #54
    Guildford West
    357
    Onthe contrary John I thank you for sharing your previous experience I feel somewhat relieved now....
  5. #55
    10,381
    Quote Originally Posted by Le Parisian View Post
    Pleased to help. As for keeping it so long, it just sort of became part of the family, and I always loved it. We went on our honeymoon in it too. And camping. And.....
    Good luck with your painting.
    Renault 4CV 1951
    Renault R8 1965
  6. #56
    Guildford West
    357
    Default 1975 Dspecial restoration
    The Sodablaster man has been and not much bog showing on the panel except for the front passenger door wihch is not repairable its also badly twisted so come on guys "someone out there must have a spare front passenger door that they dont need". prepared to pay good money for a good one will even take one with some rust .
ID:	90365Click image for larger version.
ID:	90366Click image for larger version.
ID:	90367Click image for larger version.
ID:	90368Click image for larger version.
  7. #57
    Guildford West
    357
    Slow progress but managed to remove the dash ready to weld and repair the roof rail. Revamped the rear suspension cylinders with new seals, new rubber boots, new brake cylinder rubber kits, new rubber stoppers and reconditioned spheres.
    Still chasing a good second hand front passenger door??
    The dash is still in good condition perhaps just a touch up will suffise the electrical harness is quite healthy there is lot of painting to do.
ID:	90657Click image for larger version.
ID:	90658Click image for larger version.
ID:	90659Click image for larger version.
ID:	90661Click image for larger version.
ID:	90662Click image for larger version.
    GreenBlood, ajaxvte, Dano and 1 others like this.
  8. #58
    Guildford West
    357
    Default Dspecial restoration 1975
    This weekend the roof rail rust cancer was removed and the donor roof rail prepared to fit over the existing rail. All welding spots drilled out to avoid having to remove the door surrounding rubbers basically avoiding to cut the support below; a slow job and did. The donor frame will also need some patching. Before welding the donor frame will be trialled into position secured just using with self-tappers to hold the frame into position and will temporally refit the windscreen and roof to check alignment and then if all fit nicely weld into position.
ID:	90790Click image for larger version.
ID:	90791Click image for larger version.
ID:	90792Click image for larger version.
ID:	90793Click image for larger version.
ID:	90794Click image for larger version.
ID:	90795Click image for larger version.
ID:	90796Click image for larger version.
  9. #59
    Guildford West
    357
    Not sure why but both rear cover plates are badly damaged one requiring welding??? Im not a panel beater but this looks OK....
ID:	90798Click image for larger version.
    GreenBlood likes this.
  10. #60
    Guildford West
    357
    Following M.B instructions I successfully resprayed my dash using VHT wrinkle spray from auto barn. The more paint used the thicker the wrinkle. The process is reasonably easy. Im happy with the results at least it can be touch up if required
    I dropped the glove box accidently consequently it will have to be done again
ID:	90945Click image for larger version.
ID:	90946Click image for larger version.
    Lasya likes this.
  11. #61
    Guildford West
    357
    Polishing the air duck well you must try this task one day is a good muscle exercise also just receive the radiator shroud among other things from Italy. cleaned the fan assembly anther good job.
ID:	90948Click image for larger version.
ID:	90949Click image for larger version.
  12. #62
    Guildford West
    357
    Not mutch happening this weekend, received more parts from Citroservices, a new high corrector now fitted to the front, finished the dash looks nice and tidy.
ID:	90992Click image for larger version.
ID:	90993Click image for larger version.
ID:	90994Click image for larger version.
  13. #63
    Apr 2016
    Bedford, UK
    608
    Coming along nicely. Those 'finishing touch' jobs are very satisfying.
    Le Parisian likes this.
  14. #64
    1000+ Posts garyk's Avatar
    Feb 2011
    1,054
    Dedication like religion.
    Once upon a time:
    Many R4s (incl. fourgonnette), R5LS, R16TS.
    GS 1015, 1220, sedans and wagons.
    CX 2200, 2400.
    ID 1966, 1969, DS21H, DSpecial, DS23 Pallas.
    C5 2002, 2004 petrol and diesel.
    D Special 1974
    Xantia Activa 1998 (look out Gulargambone)
    GS 5 speed sedan (what a tale)
    1986 2CV6
    CX25GTi 1985 auto
    CX2500 IE Pallas 1985 auto
    DS23EFI 1975 Pallas
    And now:
    C5 2.2 HDI 2005 wagon
    DS23 1973 Pallas
  15. #65
    Guildford West
    357
    Got the donor frame locked in place last night and the bloody welder broke down "BUGGER" this job seems like a never ending storyÖÖ..
    Fitted the windscreen and roof temporarily with very good results this is a game of patience
ID:	91039Click image for larger version.
ID:	91040Click image for larger version.
ID:	91041Click image for larger version.
    ds21bvh likes this.
  16. #66
    Sep 2013
    Elphinstone Victoria
    535
    That dashboard restoration is one of my next jobs. I hadn't thought of using an 'Artline silver' pen to touch up the highlights. Is it reasonably robust as a finish?
    SF
  17. #67
    Guildford West
    357
    Hi SF
    I’ve done this a few time on various restoration once dry its quite resilient it’s a metallic kind of paint and only cost $11.00 give it a go
  18. #68
    Guildford West
    357
    Good news the roof frame is finally welded in place and considered finished. Sealing seams and painting is next. Believe me itís a good feeling. But never again
ID:	91141Click image for larger version.
  19. #69
    Guildford West
    357
    The roof is ready for the spray painter will take it on Tuesday one of the brackets has been replaced. I will be using a genuine Citroen roof seal that I’ve had for about 20 years still soft and flexi. I’ve never glued a roof back on before but this is my plan of action I will be using Sikaflex 221 firstly I'll glue the rubber seal around the roof and once dry fit the roof lining and finally put a nice thick bead of Sikaflex right around the roof parameter and bingo making sure to have at least 3 people to guide and push the roof in place. Finally bolt the 5 roof anchor and strap the roof for good measure. I will not use the dress up rubber as Ive been told its almost impossible to fit nicely beside you dont need it if you use the bolt on rubber.
ID:	91144Click image for larger version.
ID:	91145Click image for larger version.
ID:	91146Click image for larger version.
ID:	91147Click image for larger version.
  20. #70
    Ici.
    2,408
    How are the pillar door rubber holders Philipe? I can't imagine you're scared to investigate. They are pretty notorious for disintegrating also around the bottom ends. I'm psyching myself up to repair the bottom sections of doors, figure after stripping them down and patching wasn't good enough so taking out the bad bits and replacing the offendinf sections, the rpelacement sections are thinner than e the original steel unfortunately which makes it more tricky. I would recommend you prep your roof frame with something like KBS rust blast before painting, after getting all the paint off, that stuff is very effective in retarding corrosion. Cheers me up seeing your posts as I have been going around in circles lately trying to refocus on resto!
  21. #71
    Guildford West
    357
    The apron is completed and needs to be fitted back on the car so that the bumper can also be refitted to accept the guards for alignment as well as all the remaining panels. Check the before and after pictures my panel beater is really good at repairing rust I choose Gris Brumaire AC092 as the main colour light grey non-metallic 2 Pac. looks refreshing with a white roof alpine white.
ID:	91150Click image for larger version.
ID:	91151Click image for larger version.
ID:	91152Click image for larger version.
    Attached Thumbnails Attached Thumbnails Dspecial restoration 1975-img-20161119-wa0011-002-.jpg
  22. #72
    Guildford West
    357
    The roof frame has now been sealed with por15 and should last another 40 years now preparing the front bumper for polishing whilst waiting for the roof to return from the painter.
ID:	91312Click image for larger version.
ID:	91313Click image for larger version.
    ds21bvh and mberry like this.
  23. #73
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    320
    [QUOTE=Le Parisian;1487875]The roof frame has now been sealed with por15 and should last another 40 years now preparing the front bumper for polishing whilst waiting for the roof to return from the painter.
ID:	91314Well no, actually. If the factory job, which was rubbish, lasted 40 years, your work and por 15 will last 100.
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
  24. #74
    Guildford West
    357
    Well itís been quite a hot weekend but we managed to fit the roof back on the car. Firstly we glued the seal rubber around the fibro roof and let it dry for about 2 hours using Trex power made by Soudal. Than using Sikaflex 221 we placed a nice 5mm bead around the roof gap and then fitted the roof back on, I must admit the seal rubber made the roof wider and difficult to place into position luckily the roof being fibro is flexible so with a bit of perseverance VOILA sheís in.
ID:	91628Click image for larger version.
ID:	91629Click image for larger version.
ID:	91630Click image for larger version.
ID:	91631Click image for larger version.
ID:	91632Click image for larger version.
ID:	91633Click image for larger version.
ID:	91634Click image for larger version.
ID:	91640Click image for larger version.
ID:	91638Click image for larger version.
ID:	91637Click image for larger version.
    Attached Thumbnails Attached Thumbnails Dspecial restoration 1975-20161203_170656_hdr.jpg
  25. #75
    654
    Great work Phil - nothing like refitting a nice clean and freshly painted panel.
    Well done...!
    Mark...
