Dspecial restoration 1975 - Page 2
Page 2 of 10 First 123456 ... Last
Results 26 to 50 of 248
Like Tree264Likes
Thread: Dspecial restoration 1975
  1. #26
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    357
    Great to see your progress. very inspiring. Having viewed several days posts in one evening it all makes it look so quick and easy!
    Im glad youre enjoying it, so stay put there is more to come!!
  2. #27
    Guildford West
    357
    Default 1975 Dspecial resto
    Just one picture today my second steering wheel has finally arrived it took two and a half month. will need to decide which of the two I will use....
    GreenBlood and dimistyle like this.
  3. #28
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    367
    Default DSpecial restoration 1975
    Quote Originally Posted by Le Parisian View Post
    these repo steering wheels look really good, how close are they to the feel of an original. ??
  4. #29
    Perth Western Australia
    2,640
    Well!! I would say the rubber flap kit is not too bad I bought it from Citro Services and I must say the smell is tolerable youíre right some years back it really smelled.
    Correct!! Most fuel filters that I have seen have been fitted pass the pump the location is really irrelevant the pressure of the mechanical pump is actually quite good and the filter is passive with very little drag. You will know quickly if any issues.
    Right or wrong this is my 2 cents worth.
    LeParisian,
    My comment re the position of the fuel filter has nothing to do with its efficiency as has been posted.
    My concern is if the filter springs a leak it will be under pressure and will spray over the hot engine.
    Despite comments that this is the usual place to install the filter my experience is the opposite. Thinking mechanics will realise that the filter mounted on high and under pressure is not a good thing. The engine heat is not a good environment for the plastic.
    As to efficiency it will be the same if on the suction [tank] side of the pump.
    Personal experience. I had a plastic low mounted filter [not Ryco] leak from a crack in the hose spout. Fortunately it was just that,a leak, the petrol smell giving safe warning.
    My remark re the little Solex was meant in jest and no I couldn't see anything else wrong. Nice work.
    Le Parisian likes this.
  5. #30
    10,381
    I'm with Wildebeeste. Always on the suction side. Always.
    Lasya likes this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  6. #31
    Guildford West
    357
    Quote Originally Posted by lamoor View Post
    Hi lamoor no quite as good as a new one they rebuild them using the returned units and the imperfections stays....
  7. #32
    Guildford West
    357
    Received yet again more parts this time the flexi, windscreen rubber ect.....
    I juggle between citroworld and citroservices to buy my parts sometimes one as the item and the other doesnt...
ID:	89948Click image for larger version.
  8. #33
    Guildford West
    357
    LeParisian,
    Good point wildebeest! this a good constructive comment thank you, years ago I had an engine fire at a petrol station in the middle of the city with my 1963 ID, the copper tube from the Webber popped off and sprayed the spark plug on a near 40 degree day, yeah that wasn’t fun!!!!!!! My first Citroen it happened around 1971 I managed to return it on the road, this car only had hydraulic suspension so easier to fix, bad memories!!!!.
  9. #34
    sydney-newport
    367
    which parts supplier supplied the french cakes ?
  10. #35
    Guildford West
    357
    No cake just lovely biscuits from Costco
  11. #36
    Guildford West
    357
    This weekend I remove the roof to investigate the rest of the rail for rust, it still had the original factory rubber seal the one with the wire in the center
ID:	90143Click image for larger version.
ID:	90146Click image for larger version.
ID:	90147Click image for larger version.
ID:	90148Click image for larger version.
ID:	90149Click image for larger version.
    59 Floride likes this.
  12. #37
    Guildford West
    357
    I've started the engine and it runs really well on the Solex carby. I have some issues with flexi the problem is the muffler is 1975 and the engine pipe is 1969 so the flexy needs modification. I have a small movie clip but cannot upload.
ID:	90150Click image for larger version.
ID:	90151Click image for larger version.
ID:	90152Click image for larger version.
ID:	90154Click image for larger version.
ID:	90155Click image for larger version.
ID:	90156Click image for larger version.
  13. #38
    Guildford West
    357
    The search for an old school panel beater has finally stopped I've found someone experienced in that field willing to do the job there is lot of rust cutting and plating to do. So every panels have been stripped and thursday they will go the the beauty shop. its been a very very busy weekend and as you can see I'm working in a very comfined area..
    It will be done into 4 stages
    1 Soda blasting all panels inside and out
    2 Rust cutting some new patches provided
    3 Spray painting
    4 Realignment of panels on chassis
    Roughly around 3 months
ID:	90162Click image for larger version.
ID:	90165Click image for larger version.
ID:	90158Click image for larger version.
ID:	90161Click image for larger version.
ID:	90160Click image for larger version.
ID:	90163Click image for larger version.
ID:	90166Click image for larger version.
ID:	90159Click image for larger version.
  14. #39
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    320
    Pic 6 of 9 where you're blocking the old rear vision mirror holes out - the original hole sometimes tears to the front of the door. I've seen some with extra strengthening welded behind. Our drivers door has torn. It's worth doing while your painting.
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
  15. #40
    Guildford West
    357
    Quote Originally Posted by Lasya View Post
    Thanks! will pass it on to the panel beater
  16. #41
    Guildford West
    357
    Panels packed and on their way to the beauty shop
ID:	90238Click image for larger version.
ID:	90240Click image for larger version.
    GreenBlood likes this.
  17. #42
    9,306
    Soda blasting seems to be the current fad. Have walnut shells come and gone? Have you used soda blasting previously? Any issues with paint adhesion, surface quality or post-blast prep? There are many stories about surface micro-polishing and residues. Also it supposedly doesn't remove rust and that requires re-blasting with abrasive media.
  18. #43
    Ici.
    2,408
    the best way to go is electrolysis bath with zinc phosphate coat after, gets through the metal and everywhere. I've got panels unpainted now for over 3 months just sitting and barely any surface rust appearing. Just have to find the time to put in the bottom panels and proceed to paint. No abrasion and chemically treated!
    59 Floride, Le Parisian and mberry like this.
  19. #44
    Guildford West
    357
    Never done this process before but the panel beater insisted on having the sodablasting process done prior rust repairs. he will cut the rust section out and plate the area
  20. #45
    10,381
    A year back I had my Renault 4CV soda-blasted and repainted, back to metal for the first time since December 1950. It was a very good process and the painting went well. My painter uses soda-blasting regularly and speaks highly of the process.
    The original Renault primer was tenacious and came off in the end with a phosphoric acid wipe. There was practically no rust to consider, no spidery trails of rust under the primer, so I can't comment on soda blasting on rusty metal. It did take chrome plating off pitted/grotty old diecasting that with hindsight we should have masked. I have new ones so it didn't matter.
    The photos show before during and after for the bonnet, the body after soda blasting and the final result. I'm well pleased!
    Attached Thumbnails Attached Thumbnails Dspecial restoration 1975-bonnet-hole-filling-25-nov.jpg   Dspecial restoration 1975-bonnet-repairs-26-nov-2015.jpg   Dspecial restoration 1975-bonnet-painted-17-dec-2015-sml.jpg   Dspecial restoration 1975-stripped-metal-1.jpg   Dspecial restoration 1975-two-projects-completed-sml.jpg
    Renault 4CV 1951
    Renault R8 1965
  21. #46
    Guildford West
    357
    The results looks quite stunning and the colour suits the car
  22. #47
    2,640
    The judges at Saturday's French Car Day in Perth agreed with you. It took off a Michelin / Bonjour Perth trophy.
  23. #48
    10,381
    Thanks John - after all that we didn't get a decent chat all day! Next time. I was blown away - never won anything like that before!
    Renault 4CV 1951
    Renault R8 1965
  24. #49
    10,381
    Thank you so much. We had a big family debate about the colour. I wanted to go to her original grey (they look lovely in grey) but she'd been blue since 1966 (yes, I've owned the car for 50 years now) and I was outvoted. I'm not unhappy with the results though! The surprise was just how good the metal was under the awful paint.
    And to repeat, the soda blasting really was very satisfactory.
    Le Parisian and Lasya like this.
    Renault 4CV 1951
    Renault R8 1965
  25. #50
    It's how I roll...Brisbane
    32,492
    There would be no need for disappointment there John as it looks sensational in blue and sits up nicely on the suspension, the wheels look a treat as well.
    Noice!
