DecidedlySpecial reformation.
Page 1 of 10 12345 ... Last
Results 1 to 25 of 227
Like Tree155Likes
Thread: DecidedlySpecial reformation.
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,055
    Default DecidedlySpecial reformation.
    Watch this space...
    Matthew
    GreenBlood and flipperman like this.
    8,133
    Quote Originally Posted by mnm View Post
    Watch this space...
    Matthew
    Great start Matthew, you couldn't be in safer hands
    mnm likes this.
    08 C5 X7 HDi very Noir
    mnm
    mnm is offline
    Dec 2010
    3,055
    OK... I decided to start a proper thread for the ongoing improvements to the DecidedlySpecial, first port of call is the tail lights. I will be removing the tow bar permanently, now that the car no longer lives on the street and the fact that I will never use it. Regarding the black light panel, is it supposed to be a gloss black, semigloss or matt finish?
    Matthew
    Ici.
    2,485
    I think satin/semi gloss is the go for black stuff.
    mnm
    mnm is offline
    Dec 2010
    3,055
    The first day... removed tow bar, bumper bar and light panel.
    I notice those little paper do dads are still in place.. how can cardboard survive that long???
    Do you like my original rear mud flap?
    Anyway, have sanded back the light panel... it's such a thin guage, but no rust to speak of. Just needs some fresh primer and paint. Stay tuned.
    Matthew
    9,628
    From the very first picture, I thought you might have become a man of the cloth! Tweed or velour?
    When you paint and reassemble the rear light panel, remember you have to have a suitable earth path or the lights may not work. If you use too much paint the nuts/bolts and serrated washers will not do their job. If you really like a lot of paint, then add some earth wiring. I expect you will unhappy if you paint it in a matt or satin finish.
    The repro versions of the rear mudflaps vary a lot (as does all the mostly short-lived repro rubber!), and some of the kits that are sold are made from rubber that stinks. Good original is a good choice if you can find it. I bought some pre-cut rear flaps from CTA last year and they seem to be made of a good quality material close to the original. When you drill the rivets out, keep the washers as they are an odd size and need to be refitted.
    mnm likes this.
    Citroën Tragic UFO's Avatar
    9,641
    I agree with David re repro rubber quality. I put new rubber under the leading edge of the front wings after the respray - it's cracked and useless already. Fortunately I still have the originals and will refit them one day when the wings are off.
    mnm
    mnm is offline
    Dec 2010
    3,055
    Thanks David. Yes, when I removed the panel, while the wires were still attached I had my niece help me while I labelled each wire but as I had detached the panel from the chassis, no earth.
    Matthew
    mnm
    mnm is offline
    Dec 2010
    3,055
    Poor Mum... the Magna's been relegated to the driveway to make room for my temporary spray booth.
    I've got three jobs going today, the light panel's been spray puttied, my new spare wheel rim is being painted to match the other rims and prepping the rear of the car before the light panel goes back on. First time using my new spraying equipment... the second hand compressor I picked up off Ebay seems more than up to the task.
    I drilled out the rivets of the old mud flaps... good grief! What are those rivets made from...diamonds?? Anyway, all off ready for the replacements. Saved the washers David..thanks for the tip!
    A little rust in the left elephant ear.. nothing major.
    Matthew
    mnm
    mnm is offline
    Dec 2010
    3,055
    Light panel primed and ready for top coat..
    Here are the Lucas light plates... well overdue for a revamp. Curiously the lamps were secured with those tapered nuts that are used on other panels of the car. Naturally the last person to fiddle with them put them all on backwards!!
    Matthew
    16,293
    The back end of that car looks pretty good. How were the bumper mounting tubes when you removed the bumper ? There no bent metal (rear end hits) or lines of bubles where the moisture get held (the boot lid closing panel can get moisture in it and rot out the lower part of it where you don't see... shows as a line of bubbles above and holes in the closing member if you wrap your fingers around it and try to push them through the bottom of it.
    Did you ever decide on a colour
    seeya
    mnm
    mnm is offline
    Dec 2010
    3,055
    Dismantled the bumper bar today... I knew it would be vile and it didn't disappoint. The main drama was the 4 screws that secure the top bar to the fluted pieces. Screw heads rusty and the exposed threads also rusty. Then I thought: ÿou tool.... you've got a tool!
    Richo introduced me to this little beauty... grips the head of the screw with very little clearance needed. Made the job much easier.
    Both of the end pieces are dented at the bottom and split... I have new replacements, just need to polish up the rest of the bar to match their shine.
    The mounting brackets were in good shape, attacked them with the wire brush wheel and couple of coats of Killrust enamel.
    Now, for reassembly I'm going to need 4 new screws for the top bar...according to the parts book its a countersunk head 5 X 18.
    Where can I source them?
    Matthew
    8,133
    Matthew
    Making great progress there Matthew,
    I had similar fun dismantling the rear bumper on mine and replaced all the bumper fixtures with stainless sourced from Whitworths Marine. Not strictly correct but I was able to pretty well match everything in stainless including washers.
    Lasya likes this.
    mnm
    mnm is offline
    Dec 2010
    3,055
    I love getting things in the post...
    Stainless steel polishing kit arrived today... see what it makes of my bumper bars..
    I'll be doing some mechanical work next week... look what my brother Stephen fabricated for me! Thanks Stephen. No Polly, you can't eat it.
    Matthew
    mnm
    mnm is offline
    Dec 2010
    3,055
    OMFG!! Thank you Mr Citroen for making the shiny bits in stainless steel! The kit I bought is for a bench grinder. Had a practice run on the old end piece first... First pass with the hard sisal wheel and the grey fast cut bar.... second pass with the green bar and the stiched sisal wheel...
    I then attacked the top piece, same method and then finished with the polishing paste and soft calico wheel. I can't get over the result.. it looks brand new. A very satisfying outcome. Look at the front bumper bar in the pic..hmmph..trash!
    Matthew
    mnm
    mnm is offline
    Dec 2010
    3,055
    All done...ready for reassembly...
    Matthew
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,820
    Brilliant
    Every day is a good day
    Ici.
    2,485
    You 're pretty lucky the rear end is in such good condition Matthew, the bumper mounts are usually ratshed these days, good to follow your work, bit every day!
    mnm
    mnm is offline
    Dec 2010
    3,055
    Well that's a bit of all right eh?
    Here is a pic of the rubber tubes for the bumper bar mounts. See how they are compressed? So should I fit new ones? That means the bar will sit further out from the rear of the car... not by much of course.
    Matthew
    8,133
    Icon7
    Matthew
    Looks like a bought one Matthew, stunning!!!
    The rubbers don't look too bad, maybe the one on the left has seen better days - if you were to replace one you would obviously replace both. The new ones will compress and look like the one on the left once the bar is tightened.
    mnm likes this.
    mnm
    mnm is offline
    Dec 2010
    3,055
    Ok.. well it's time to come clean. Today was a fun day, reassembly day! As I mentioned to HRH on another thread I've been in a twist over which tail lights to go with for the reformation. My choice may urk the purists but as the title of this thread suggests I'm making some changes, so get used to it.
    The Lucas lights are out and the Pallas 68/69 lights are in... the reflectors on these beauties are quite unique and I think suit the design cues of the car better. The ribbing on the lens is very cool. Pics don't do it justice.
    I decided on satin black, a better backdrop to the bling of the lenses and the bumper bar.
    Here are the bulbs in place, 5W at each end and courtesy of Richo a 15W Norma bulb with the cool finish on the glass. As pointed out on my light bulb thread, the 21W bulb is too long for this lens.
    Curiously with the wiring, there were extension pieces in use for the lucas lights and the mauve connector was taped up. I removed the extension and hooked up red, green and mauve and all seems good. No drama with the earth either David.
    I also gave the rear guards a blast with the water blaster and applied some fresh underbody deadener.
    Bumper bar tubes were pretty good on closer inspection.. still mostly pink undercoat so cleaned them up and gave a fresh coat.
    Finally, if you're wondering what happened to my Lucas lights, I decided to restore the plates and fitted the new lenses I bought years ago. You may recall I was going to set up a triple combo with the reversing lights but that would have meant hacking extra holes in the light bar and the original mounting plates. This way anything I've done can be reversed. While not strictly correct for my car, I have a pair of Gelbon reversing lights to fit later.
    Matthew
    GreenBlood and forumnoreason like this.
    mnm
    mnm is offline
    Dec 2010
    3,055
    Moving right along... Gelbon reversing lights done. I chose these over the Cibies as they have a lower profile. They are quite bright. I would have been happy to leave them off all together but in Sydney traffic it's much safer that people know your reversing! So a bit of a compromise.
    So the next thing to do and the main reason for this visit is to practice painting a spare rear fender I have and see if I'm happy with the result, enough to do the whole car myself. I have a pot of my chosen colour made up so it will also give me a chance to see it in the flesh.
    Here's the panel after I stripped off the paint with one of those purple discs. Pretty easy really and beats sanding it back or using paint stripper.
    Etch primed... spray putty tomorrow...
    Matthew
    Ici.
    2,485
    Jesus you 're going like greased lightening dude! Tres bon!
    mnm likes this.
    674
    Hi Matthew,
    Great job - keep up the good work...!
    Where did you source the new lenses for your lucas lights - I have a set of these on my 69 and although the lenses are good, new ones would be nicer now I've seen yours...
    Many thanks in advance,
    Mark...
    mnm
    mnm is offline
    Dec 2010
    3,055
    Quote Originally Posted by ds21bvh View Post
    Hi Matthew,
    Mark...
    Hi Mark
    here's the link..
    Classic Bits items - Get great deals on items on eBay Stores!
    Matthew
