White C5 at Pickles, Melbourne
    Dec 2010
    Wollongong, NSW
    497
    Default White C5 at Pickles, Melbourne
    Hi All,
    Just in case I need the engine for my timing belt woes, can anyone tell me whether the White C5 at Pickles Tullamarine has a 2.2 Hdi motor? It looks like it, but the picture of the engine bay isn't good enough to tell.
    Did/does it belong to anyone here? If it isn't too expensive, it could be an easier option than taking the head off mine to check for damage etc...
    Regards, Erik
    Don't remind me!
    16,609
    Will they reveal the VIN? You could then check weasily.
    9,777
    If it's the series 1, it won't be. That engine only came in the first of the restlyed C5 from early 2005 and you are looking for 4HX in the VIN, not RHZ, which is a 2.0HDi. VIN is on the photo of the ego label if it's the right car.
    Possibly the cheapest option for you right now is to replace just the broken rollers/rockers and see if it runs properly. If it doesn't run properly or the injector correction is all over the place, then you would then have to remove the head and check the valves and piston protrusions to be sure of the condition. The bottom end would most likely be OK as it's not been hydraulically locked.
    Dec 2010
    Wollongong, NSW
    497
    Further to the query...
    My car is a HXE engine and this one is a HZE.
    Does anyone know if they are the same engine???
    Thanks, Erik
    Dec 2010
    Wollongong, NSW
    497
    Whoops, should have refreshed the thread first. I didn't realise you guys were so quick. So even though it looks the same in the pics, in terms of the oil filler cap being at teh back and on the drivers side, it sounds as though it is the smaller 2L Hdi.
    thanks.
