Xsara door handle
Results 1 to 8 of 8
    177
    Default Xsara door handle
    all,
    i blame the very cold SA winter we are having but the driver's door handle broke on my Xsara last week
    it is a simple black plastic moulding which has failed in the two sections that are connected to the door mechanism
    i tried undoing the two fixtures visible from outside the car - but no tool i have appears to mate with it - including those funny Allen-key like fixtures common on the Xsara
    i also took the inside of the door off and took a look inside - access to the door handle attachment is highly problematic / impossible
    any suggestions appreciated - don't want to burn $$ on something i can do myself
    Jeremy
    8,184
    Icon3
    Quote Originally Posted by robjer View Post
    all,
    Jeremy
    Jeremy,
    I had the same problem a couple of years back so my memory will be tested
    I purchased a replacement via ebay UK, this seller was very prompt.
    http://www.ebay.co.uk/itm/CITROEN-XS...item27c8c56610
    You may find our service centres now carry stock, at the time I needed one they didn't.
    From memory, you release the old handle by drilling out the rivets visible on the outside (or did I drill from the inside ), whichever, you need to remove the door trim to fit the new. Instead of rivets I used 2 x M5 nuts and bolts and washers.
    08 C5 X7 HDi very Noir
    177
    brilliant!
    thanks
    drilling from outside yes - can't see how there's room to secure new handle from inside but will see how i go
    Jeremy
    177
    hi again
    that fella on ebay doesn't do international postage ...
    got a quote from a parts place in Wagga for $73 + GST + postage
    bit steep no?
    JR
    8,184
    Icon3
    hi again
    bit steep no?
    JR
    Did you make contact with the seller? I see he doesn't show that he'll post OS but he certainly did for me...
    In reality 27GBP converts to around $40.00AUS add postage and a two week wait and you may be better off buying local?
    177
    the "no international shipping" was on his Q and As but maybe he makes exceptions
    i'll send a message ..
    $70+ sounds like a rip off to me
    177
    hi again
    bought this one - also in UK / ebay but cheaper
    http://www.ebay.co.uk/itm/CITROEN-XS...ht_1886wt_1185
    FYI that other bloke said postage to Aust was 5 pounds - but the other was still cheaper with 10 pounds postage
    two quotes from Australian suppliers were $74 and $87 (both genuine Cit i think)
    cheers and thanks again
    8,184
    Icon14
    hi again
    Nicely done
