CX not rising
Thread: CX not rising
    Fellow Frogger! salman's Avatar
    Jan 2005
    Melbourne Australie
    196
    Default CX not rising
    This is a Prestige I restored 9 years ago,its overseas.Need some quick thoughts.
    It was parked for a long time,now on starting refused to rise.I adviced to clean reservoir and prime pump.He has done this but still no lifting.Its hard diagnosing from far away but any suggestions welcome.
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,048
    Height lever is on low?
    Is it a late model one like a series 2? It might have a motorised height control like the Xantias that has got stuck?
    Need more info please.
    Ken W
    Jan 2005
    Melbourne Australie
    196
    Default early type
    Sorry should have mentioned its 1982,Petrol.
    16,716
    It just wont have bleed. Tell them to try again. Sometimes there real [email protected] to bleed. They need to check the feed line for fine cracks in the suction hose, and the hose clamps too.
    Jan 2011
    5
    When mine had this problem, also after sitting for a long time, it tuned out to be the priority/distribution valve.
    cheers,
    Martin
    10,126
    Bleed valve on the regulator is open? Does the regulator cut in/out? Could the spheres be so flat, that it's filling them and pumping itself dry?
    The last time I encountered a hydraulic Citroen that refused to rise (unless revved quite hard), was a D Special with a crack in the pump body. It was leaking badly internally, so not creating pressure and also weeping out the front. The low pressure prevented the priority valve from supplying fluid to more than the brakes. I think the CX would be the same, so it should also not have steering assistance.
