Clutch shudder DS
Results 1 to 9 of 9
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default Clutch shudder DS
    What is causing the clutch shudder on my DS. Doesn't happy all the time only 1st gear and certain load or revs.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Mar 2011
    Broom
    819
    Adrian, if you have a good torch, have a look at the bracket, fixed to the bell housing under the water pump, where it joins the clutch cable, the hook on the end of the bracket where the cable connects can get stretched out of shape, the bracket could need replacing. Or you could have a leak from the H Pump that is letting oil get onto the clutch plate through the bell housing. Or perhaps the cable is on it's last legs, again, something you'll be able to see if you shine a torch down onto the bell housing where the cable joins the bracket. I think I have a spare cable if you need it, but i don't have a bracket unfortunately.
    mb
    16,691
    check the water pump too.... you could have coolant leaking down onto the clutch You could also be getting weapage from the primary gearbox shaft seal, or rear main.... you don't want to go there though
    Jan 2011
    749
    Thanks guys. Michael I'll give you a call soon.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    1000+ Posts michaelr's Avatar
    1,393
    What condition are the engine mounts in? It could be slumped rubbers allow the motor/transmission to jump about.
    Michael
    Member, Citroen Car Club NSW
    Jan 2011
    749
    Engine mounts are newish, it's not that.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    May 2012
    393
    Hi Shane / IE23,
    I have some clutch problems, shudder causing kangaroo hops, grating gears, in my new 66 (65?) ID19. And guess what (Shane you spotted it), the water pump is leaking at the shaft and dripping directly onto the open area where the clutch lever operates. May not be causing the gears crunch, but it is not going to help.
    IE23, did you get to the bottom of your problem and eliminate it?
    Cheers Leconte
    Jan 2011
    749
    Leconte, the shudder has minimised to the point that it doesn't bother me since I fixed the fuel supply issue, which was a blocked fuel filter. It maybe pure coincidence but once the fuel supply was fully up to performance the shudder almost disappeared.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    Ici.
    2,649
    Diagnostic advice on tap here! If those suggestions don't work then time to get an Up!
