DS23 74 Injection problem........FIXED
Results 1 to 9 of 9
    Feb 2002
    Coolum Beach
    2,046
    Default DS23 74 Injection problem........FIXED
    Done, it took me a whole year, but I cornered the [email protected]#$%^&.
    The guilty part was the pressure regulator. I avoided it like the plague for a long time because the bugger was nigh impossible to get to.
    I finally removed it and wasn't able to re-install in the same spot , so did a bit of re-engineering myself, and presto the D now starts, idles and behaves.
    So....for anyone with insolvable injection problems: I suggest:
    New pump, new plugs, new pressure regulator.
    Be prepared to loose skin, blood and hope, but in the end.....it works!
    Attached Thumbnails Attached Thumbnails DS23 74 Injection problem........FIXED-dsci0006.jpg   DS23 74 Injection problem........FIXED-dsci0005.jpg
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
    16,691
    Um............................ Wasn't checking the fuel pressure the very first thing I suggested
    seeya
    PS: Been there and done that!
    Feb 2002
    Coolum Beach
    2,046
    I should have listened!
    16,691
    The original fuel pressure regulator is adjustable. Do you think someone might have messed with it's settings When the regulator died on my CX it's pegged my pressure gauge against the back of the "0psi" stop.... Wow, I drove it home from QLD like that how did it not burst a fuel hose and burn the car
    Feb 2002
    Coolum Beach
    2,046
    Icon6
    No I don't think so. Probably died of old age? But I must've made it worse when I installed a brand new fuel pump last year. The symptoms progressively got worse.
    Now, next week is reserved for an oil change as I am sure there must be half a litre of fuel in the oil by now,..... and that can't be good.
    10,090
    Good to hear it's running now. I've had the fuel in the oil problem too! Yes, a god idea to change it if it's been flooding and misfiring a lot.
    If you plan to leave the regulator in that position, secure it to the manifold so it can't move around. There's also meant to be a clip securing the inlet pipe on the front half of the fuel rail to a bracket on the front of the head. It's under the hose going to the heater.
    Fellow Frogger! CorneSoutAfrica's Avatar
    South Africa
    589
    Congratulations!!!!!
    Now you HAVE to take her for a drive!! I am so jealous!! Mine is still parked in the garage i hope you enjoy every driving moment!!
    Corne
    1968 ID21 break
    1971 DS21 IE BVH Rouge de grenade (Madamoiselle Rouge)
    1974 DS Pallas Sable metalisse My first restoration (Edith) Now BVH
    1973 DS pallas Metallic red. "Rusty"
    1947 Traction Avant
    Modern
    2006 C4 VTS 180 Coupe
    What would life be if we had no courage to attempt anything?
    - Vincent van Gogh
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    What were the symptoms?
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Feb 2002
    Coolum Beach
    2,046
    Quote Originally Posted by IE23 View Post
    Started fine, ran for a few minutes, then started coughing, at the same time, horrid smelling black smoke would come out the exhaust, then died. Couldn't restart for a while. But after 15 minutes, could restart and start the whole cycle again........
