Dee Diaphrams
Results 1 to 18 of 18
Thread: Dee Diaphrams
    Kapunda
    493
    Default Dee Diaphrams
    Just driving the D Spec home today,I got a ruptured diaphram on one of my front sheres,the LHM resy sounded as though it was boiling,but no harm done(other than the sphere)I notice that, there are 2 types of diaphram available,the original type black ones and some translucent white ones,any observations are welcome.
    Woody
    Fellow Frogger! CorneSoutAfrica's Avatar
    South Africa
    589
    Brian
    Get the translucent ones, they are much better and last longer, the lhm seems not to attack the rubber as much as the black ones
    Corne
    1968 ID21 break
    1971 DS21 IE BVH Rouge de grenade (Madamoiselle Rouge)
    1974 DS Pallas Sable metalisse My first restoration (Edith) Now BVH
    1973 DS pallas Metallic red. "Rusty"
    1947 Traction Avant
    Modern
    2006 C4 VTS 180 Coupe
    What would life be if we had no courage to attempt anything?
    - Vincent van Gogh
    Symar/ca/usa
    607
    Quote Originally Posted by CorneSoutAfrica View Post
    Brian
    Corne
    Hi Corne and Brian,
    The black LHM compatible diaphragms, if made correctly, are molded from a Nitrile rubber compound. The translucent diaphragms are molded from a thermoplastic, Desmopan, made by Bayer Chemical. Neither compound is attacked by LHM or any other mineral oil based fluid. The principal differences are mechanical strength and gas permeability. The advantage of good rubber diaphragms is that they 'leak' gas pressure at a much slower rate than thermoplastic ones. OTOH the Desmopan molded ones are stronger mechanically. Either will work fine - the real trick is getting quality ones. The Desmopan diaphragms are made, I believe, by IFHS and are of excellent quality. The rubber ones, frankly, seem to be a hit and miss affair - not sure who is making them and if they are coming from one source or several.
    Steve
    CitroŽn Tragic UFO's Avatar
    9,791
    Richo has been using Desmopan diaphrams with great results, as have many others.
    Symar/ca/usa
    607
    Hi Craig,
    I have been using them since they became available. All of the welded ones, AFAIK, also use a type of Desmopan - of which Bayer makes a boat load of versions. OTOH I have a set of replaceable shock body units on my 72 with rubber diaphragms that have been there for coming onto 80,000 miles and have not had to 'top' them up since installed 7 years ago. However when I do up spheres for customers and they are LHM cars, I use the Desmopan also. I just warn people that they need to look after the pressure in the units every 24 to 36 months. So long as they are kept at the proper pressures, they will last a long time. The same holds true for good quality rubber ones, though those are getting a lot harder to source these days.
    The real problem we all have, and have been in contact with Andre, Richo and others, is sourcing decent LHS compatible diaphragms. Those have detoured to that part of the Periodical Table where the material known as "Unobtainium" is listed .
    Steve
    Don't remind me!
    16,609
    I'd been under the impression those Desmopan diaphragms were reasonably tolerant of LHS. You probably saved me a misadventure by saying they aren't.
    Symar/ca/usa
    607
    Andre and I had a long discussion about this in Saratoga Springs, NY over June 15th weekend at the Rendezvous held there. He has been experimenting with them - IIRC he has them in one car. The problem with urethane based plastics and glycol based fluids is that material attack can be quite temperature dependent. IOW at moderate temperatures - say in the 20 to 30 C range - it may appear to have OK resistance. Move the temps up to the to 60 to 80 C range (as found under hood in LA or Sydney during the summer season) and the materials can quickly be compromised.
    Attached is data from Bayer Chemical with testing they did on Desmopan 453 and Texin resins. Note the loss of tensile strength, tear strength and softening in Brake Fluid compared to the results for oils (which LHM would fall under).
    Steve
    Don't remind me!
    16,609
    Thanks for that.
    Writing's on the wall, it seems. Bummer; I had wanted to keep the car in question on LHS, although this was at least in part simply cussedness.
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,446
    I'm a desmopan fan for LHM. 2 year guarantee from me rebuilding a sphere with Desmopan diaphragm.
    No guarantee from any supplier.
    Rubber diaphragms available for those who would prefer them, but my 2 year guarantee is not applicable.
    I do have some reservation as to whether the diaphragms are Desmopan 453 or another Desmopan formulation. I have seen and used a couple of different types, identified by their colour.
    No source of the diaphragms is knowing their formulation or have had the type disclosed, despite requests.
    Re LHS: "Houston we have a problem".
    Nobody, currently, is making anything I would guarantee.
    This is something which I have discussed personally with a number of peers, including Steve Hammond, Andre Pohl and others in both Europe and the UK.
    Kapunda
    493
    I now feel most enlightened,can someone tellme the best scource of the Desmo diaphrams.
    Woody
    Symar/ca/usa
    607
    Quote Originally Posted by richo View Post
    Richo,
    Some years ago - maybe 7 or 8 on the Bayer site - they had a reference to 481 being used for automotive suspension diaphragms. Some time later I went back and that reference was gone. With the original webpage they also stated that the resin could be had in a number of different colors as well as translucent.
    Steve
    Symar/ca/usa
    607
    Quote Originally Posted by brian woodcock View Post
    Woody
    Woody,
    Personally I get mine via Citroworld (Geert Bukkems) - but Andre Pohl, Chris Brownhill and others also carry them.
    Steve
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,474
    I just love AussieFrogs. It encompasses the whole gamut from French letters to D Diaphragms.
    No wonder current Citroens bare no resemblance to the old classic Citroens. We've stopped breeding them. Too much contraception.
    John
    Oct 2011
    Toowoomba
    650
    Default Sticky rubber.
    I had to replace some diaphrams recently (Ian Steele at Maleny) When we got the rear spheres apart there were some patches where the rubber had stuck to the steel, and torn when the oil was pumped in (car had sat for several years) It had, in the past, had Dexron in the hydraulic system, but it isn't known if this was the reason the rubber diaphrams stuck to the steel.
    Jan 2006
    1,446
    Unless you knew how long the spheres had been on the car, whether they were charged and at what pressure, how long the Dexron had been in the system, age of the fluids, oxygenation, if the two liquids LHM and Dexron had been mixed together along with the origin of the diaphragms, there could be no subjective, definitive or educated answer.
    Too many variables and unknown conditions.
    Symar/ca/usa
    607
    Quote Originally Posted by Bruce Llewellyn View Post
    If the diaphragms were LHM ones of good quality - the Dexron would not have caused the rubber to stick to the steel. Have seen this in the past with both LHM and Dexron cars where the spheres were devoid of gas and cars sitting for along period of time.
    Steve
    Oct 2011
    Toowoomba
    650
    Quote Originally Posted by Citroenfan View Post
    Steve
    That means my spheres died of sheer cussedness!
    Oct 2011
    Toowoomba
    650
    Default Perversity.
    The car sat with dextron in it for 12 years. Spheres were re-gassed. Car was run as a daily for several years with LHM and then sat again. Diphrams tore on the next pump up. There is an age factor, as with most elastomers here too.
