C5 is bent
Results 1 to 16 of 16
Thread: C5 is bent
    South West Sydney, NSW
    245
    Default C5 is bent
    Hey froggy folk.
    The C5 isn't happy tonight. I had just left the station to head for home when a guy reversed into my path. Left front wheel and guard took the brunt of the impact. Scratches on the guard when I drove off I then had to drive home with the wheel turned a quarter turn to drive straight. Left turns were very wide and felt like the wheel was loose.
    Also a strange clicking sound at idle that wasn't there this morning. A clunking noise when I drove into the complex. Gearchanges/clutch were fine in operation.
    Guard itself is undamaged apart from paint but worried about the front suspension. Any opinions as to what I am facing? I suspect a bent strut/stub axle. Opinions appreciated. Other party admitted liability.
    Andrew
    11,225
    Quote Originally Posted by Andrew D View Post
    Hey froggy folk.
    Andrew
    Have you jacked it up and really rocked the wheel, then pulled it off and looked hard, and checked whether something might fall off? I would not dare drive it in that condition. Apart from the risk, you might (an old theme) find you are not insured if the car is not roadworthy - and it doesn't sound as if it is. If you hit someone driving it in that condition (much more expensive than something) the damage claim potential is catastrophic. Let alone the risk to the other road users.
    It's had a bang that might have bent steering arms, and or broken links to anti-roll bar, or other things. It might even have damaged the gearbox with a bad bang on a driveshaft.
    My advice is to have a very, very good look at it before you drive it again and probably get it trucked to the service place you use to get it on a hoist and really sort out what is wrong.
    Bad luck, to say the least.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Armidale
    2,548
    Clunking noise when moving could be a "prematurely aged" CV joint, but obviously could also be transmission. New noise at idle definitely sounds suss...
    I second John's advice that you should not be driving it - apart from the danger to yourself and others, you might be making something (eg. transmission) much worse.
    Alec
    CitroŽn Tragic UFO's Avatar
    9,787
    Assuming you got all details of the other driver, make a Police report 131444 and also contact your insurance company to put the repairs under their management.
    As John said, do not drive it any further.
    Don't remind me!
    16,609
    If you're with NRMA and claim on your own policy they will write it off. If the third party is with Zurich or Shannon's you have a better shot at getting it fixed. If you are getting jerked around in the claims process, call the FSO.
    245
    Thanks all.
    Tow truck booked to collect and we will see what they find out.
    I'd be very disappointed if they write it off. Manual c5s are rare enough on our roads and it's a bit special with leather and sunroof.
    Insured with Bingle so we will wait and see what happens. The other guy is at fault and insured with Allianz.
    Andrew
    Don't remind me!
    16,609
    I've recently been through some ugliness with insurers; if you do want the car fixed there are a few ways to go about it - but you have to keep threatening them with the FOS.
    No respect for Allianz, but I have called their bluff too - used a "heavyweight" accredited valuer to dispute their pricing.
    At some point shortly (if not already), your insurer will make a recorded call to you, where they ask for your consent to whatever may follow - the most important detail here if you want the car fixed, is to clearly state that you will reject any proposal to write it off, and do not give them permission to make this judgement call.
    Without your permission they can't actually write the car off - otherwise assessors could ponce down the street declaring every other car a write off based on the cost of restoring it to 100% of original condition. They greatly dislike being reminded of this catch.
    monbulk
    654
    Have a look in drive.com or equivalent. What is a top example of your car (or another model that you lust after) worth? What will your insurance give you?
    My Pug ' 98 406 was written off (hail) paid out $10k for a 210 oookm example
    Purchased a 2007, 2.2td C5 with half the Ks for $4000 more. I'm happy.
    David
    245
    An update
    Popped in to smash repairers on Saturday. Repairs have been approved and parts have been ordered from France with 2+ weeks. It Looks like they have cleaned up the panel without having to paint it.
    I always thought that to sell cars in Australia you had to hold 10 years worth of parts?
    So looking down the barrel of at least a month before the car is back on the road.
    Andrew
    Armidale
    2,548
    Great to hear it's not a write-off! Are any mechanical parts being replaced? How were drive shaft and transmission?
    Alec
    Don't remind me!
    16,609
    The way it works, is your panel basher gets an "authority to repair" from the insurer, following the assessor's visit.
    Once it's locked in and parts are on their way, or during reassembly, they suddently discover "Oh goodness, we hadn't noticed the bent strut!"... So an extra cheque is written to top up the claim payment, stopping the car from being written off and allowing the beaters full margin on more new parts.
    245
    This is how the car looked after the bingle (see attached photos).
    Attached Thumbnails Attached Thumbnails C5 is bent-picture-065.jpg   C5 is bent-picture-066.jpg   C5 is bent-picture-067.jpg
    11,225
    All fine Andrew, but what about all the mechanical noises etc etc?
    245
    Parts from France are due next Friday.
    From what the smash repairer said it was the front suspension, bent stub axle and assorted bits. i won't know anymore until such times as they putt it apart.
    Once it's all back together, I'll take it across to my mechanic for an assessment. If it's not right, it will go back and they can have another go. This process will go on until I and my mechanic are satisfied.
    It also seems the parts issue isn't restricted to Citroen. I spoke with the panel beater today and he has a Toyota Kluger and Mazda3 awaiting parts from Japan. A friend has also relayed another story of a bonnet for a Mazda3 that took over a month to appear.
    11,225
    There have always been horror stories about Japanese parts for less than brand new models and about their prices.
    Best of luck with it. If the stub axle is bent, with any luck that gave all sorts of horrible noises.
    Jul 2012
    15
    Just on the insurance scenario, the insurer can not have an insured person's vehicle written off, however it can settle the claim on the basis of the lowest valuation, be it based upon either the repair or the accepted market value. On that basis you get to keep the car if you want to, less it's salvage value up to either the repair or market value whichever is deemed the lower. It's always your vehicle not an insurers so you can do what you wish with it...
