C4 Tourque setting for harmonic balancer
    Mar 2012
    Blaxlands Flat NSW
    42
    Default C4 Tourque setting for harmonic balancer
    G'day C4 Experts, I'm having to replace the cam belt roller on my C4, I had the belt replaced a short time ago and when the mechanic checked it had a slight play in the bearing of the idler roller, so I bought a new roller and am about to replace it. I have pulled all the covers off and the harmonic balancer/accessories pully but don't have the tourque figure for the main bolt which holds the accessories pully onto the crankshaft.My C4 is the 1.6 ltr diesel 2007 mod. Thanks RT.
    Sep 2003
    North Parramatta
    4,011
    Here you go - I think this is the bit you mean.
    In case your VIN has a 9HX in it instead, it is the same figure.
    Attached Thumbnails Attached Thumbnails C4 Tourque setting for harmonic balancer-accpulley.jpg
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Mar 2012
    Blaxlands Flat NSW
    42
    Thanks Simon would you know what this means in english "ft. lbs" to me what they say is double dutch. the bolt is number 20 . Cheers R.T.
    Jul 2005
    328
    Torque unit converter: http://www.lorenz-messtechnik.de/eng...alculation.php
    Or 26 ft.lbs, then tighten a further 190 degrees.
    '96 Peugeot 405 SRDT Station Wagon
    '71 Peugeot 504 GL - gone
    '91 Peugeot 205si - gone
    Mar 2012
    Blaxlands Flat NSW
    42
    Thanks fellas, Its a wonder they dont just give a final Ft. Lbs. like most other vehicles do. Thanks again. RT.
