Accumulator leak
Results 1 to 9 of 9
    Jun 2012
    18
    Default Accumulator leak
    Morning all,
    Last weekend, I flushed the LHM and pulled the spheres off the car for regassing. This morning, I found a big pool of green blood under the BX 16V this morning that had leaked from the accumulator pressure release screw. I couldn't see the cause so I loosened the screw off, cleaned it up then re-tightened it, and that fixed the leak. But as far as I could tell, it wasn't that grubby to begin with
    Has anyone struck this before? What's the likely root cause?
    Thanks,
    Duncan
    Fellow Frogger! frog's Avatar
    Feb 2006
    600
    Hi Duncan, you're sure the leak was out of the bleed screw? I would check the sphere is tight and the O'ring is seated correctly. Wouldn't hurt to inspect and check the tightness of the high pressure pipes on the FDV too.
    Chris.
    11,225
    Quote Originally Posted by duncan16v View Post
    Morning all,
    Thanks,
    Duncan
    Did you replace the square ring sphere seal and fit the seal, lubed with LHM into the base before spinning the sphere on?
    Never heard of the bleed screw doing that when nipped up.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Member Sturla's Avatar
    Nov 2005
    Bergen, Norway
    73
    If you have flushed the system it might develop a leak from the "top" of the pressure regulator. The o-ring there might be bad. I have had that happen 2 times, on two different LHM citroens after flushing the system with hydroflush.
    -74 DS23 bvh, -78 CXgti, -85 CXgtiT1
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,047
    I think a bleed screw can leak a bit it not done up tightly.
    Jun 2012
    18
    Thanks all.
    Jun 2012
    18
    Just to close this off: the culprit was the O ring on the pressure release screw. I pulled off the pressure regulator, cleaned it up, replaced the O ring and pipe seals and not a drop of LHM to be seen now.
    Hurrah!
    CitroŽn Tragic UFO's Avatar
    9,787
    Just to close this off: the culprit was the O ring on the pressure release screw. I pulled off the pressure regulator, cleaned it up, replaced the O ring and pipe seals and not a drop of LHM to be seen now because it has all been pumped out and ran down the driveway.
    Hurrah!
    Fixed it for you
    Good to know you have sorted the problem. It's always handy when the OPs provide the resolution to the problem and thereby increase the knowledge base.
    11,225
    Hurrah!
    Thanks for letting us know. Good it is fixed.
