Berlingo gear linkages?
Results 1 to 3 of 3
    8,159
    Icon5 Berlingo gear linkages?
    We have a mechanic next door to us at work, just does general mechanical work for the masses.
    He has a customer's Citroen Berlingo in at the moment that keeps throwing a gear linkage rod, he has replaced with genuine new replacement but the problem persists. He says the ball connection is as good as new and the new rod is a firm fit, but the rod end is just short of the ball.
    He has asked me me (as if I'd know ) if I knew a possible cause, he is looking at gearbox/ engine mounts.
    Any tips/tricks?
    08 C5 X7 HDi very Noir
    9,670
    Engine/gearbox mounts are one possibility. Possibly the driver if he/she regularly tries to ram it into reverse. It can bend the flat ends of the long selector rod and then the linkages are not located as planned. It may not be obvious unless he knows what 'bent' looks like. There is also a bracket on the gearbox and it was modified at some stage (by moving or raising the ball slightly) to stop the link that hooks onto it contacting the back of the bracket. Replacing just one short link in isolation doesn't always fix it.
    8,159
    Icon12
    Good stuff, thanks David, I'll pass on your info
