Price of an ID motor
Results 1 to 8 of 8
    Fellow Frogger! d coupe's Avatar
    Oct 2005
    Geraldton
    125
    Default Price of an ID motor
    Hi All
    Been offered an ID motor (1911cc) that is supposed to be in good condition, on that premise does anyone have any idea of what a fair price would be to pay for it?
    Wayne
    16,716
    I would have thought very little .... unless it has had a recent rebuild with receipts to prove the work that was done on it
    seeya
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,446
    Wayne,
    Buy the seller not the story. Particularly if you cannot inspect the motor first.
    If the engine is on a stand, remove a main bearing cap and a connecting rod cap for inspection.
    Remove the rocker cover and inspect as best you can the rocker arm tips and if permitted remove one of the rocker arm assemblies. The condition of the bushings will allow you to judge if the oil flow was good and if the rocker bushings are worn out.
    If you can't look at the motor initially, or be provided with details of the conditions described above, refer to my initial sentence.
    Unfortunately, your question does not give detail sufficient to reliably advise further.
    Your personal experience is considerable.
    Hope this helps.
    Oct 2005
    Geraldton
    125
    Default ID Motor
    Thanks Guys
    The motor is supposed to have come out of a car as a runner and belongs to a fellow Citroenista, in my view without seeing it is worth about 100 - 200 dollars. If the head is good that would be the main thing everything else is easily replaceable. At the end of the day we dont really need it as we have just rebuilt a new motor for our ID hense not paying alot for it, at the end of the day we dont want to sour friendships
    W
    16,716
    I was thinking $300 for any motor that runs ok without visible signs of tiredness (eg: blue smoke under load or rattly bottom end). The top ends always seem to be tappy.
    It's a shame you don't want CX engines, I could offer you a selection to choose from. The only way to kill them it seems is to cook the sh!t out of them.
    Oct 2005
    Geraldton
    125
    I know what you mean already have a couple of them, only real problem we had was a 2400 block developed an internal leak (cracked around the webbing for the liners)
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,405
    A couple of hundred dollars sounds reasonable to me. I have paid more for a D engine (trusted seller); I have paid less (dubious provenance). Alternatively, you could avoid putting a monetary value on it and swap something for it.
    Roger
    NORTH PERTH W.A.
    853
    are we talking 3 or 5 bearing? I may need a 3 bearing one when I finally get back into the one the child rebuilt Anyone that forgets to shim the timing gear could have forgotten one of the pistons !!!
