C5 Rattle
Thread: C5 Rattle
    May 2012
    6
    Default C5 Rattle
    Hi All,
    Have developed an unwelcome rattle seeming to be coming from 'deep within'.
    The video below best characterises the problem.
    http://www.youtube.com/watch?v=bnauXYhqhJs
    citroen c5 rattle problem
    Any ideas before I take it to the mechanic and they start from square 1??
    Thanks!!
    Mal
    16,717
    That's distinctive. I bet someone here will know it. I wonder if it's the sound the alternator clutch makes if it's about to fail.
    10,128
    HDi? What year? If it's an HDi, I'd guess either the alternator pulley one-way clutch is frozen or the 3 part damper is about to fall apart. It depends on what your car has. For the HDi, it should have either a fixed alternator pulley and a 3 part damper OR a one-way clutch in the alternator pulley and a 2 part damper. As the noise has suddenly started, it shouldn't have an incorrect mixture of bits. If the alternator pulley is held on by a nut, then it's most likely the crank pulley at fault. Does it have a plastic cap where the nut would usually be? If so, then it's probably a one-way clutch inside the pulley. It sounds more like a 3 piece crank pulley with failed rubber bonding. If the crank pulley falls apart, your timing belt is at risk and that can ruin your engine. Better to seek proper inspection/diagnosis by a mechanic.
    May 2012
    6
    thanks a lot for the feedback.
    It is indeed an HDI- I will have to get back to you on model- I think 2003/4.
    I will start looking for a solid mechanic- if you can recommend any in Brisbane- let me know!
    Thanks again!
    Mal
    Mar 2005
    920
    Euroserve in Newstead would be my first call.
    Feb 2002
    Coolum Beach
    2,048
    DS Motors , Woolcock Street Red Hill
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
