Citroen Workshop in Perth
Results 1 to 12 of 12
    Fellow Frogger! renaultmark's Avatar
    Dec 2010
    Pelican Point WA
    163
    Default Citroen Workshop in Perth
    Hi everyone
    Is there anyone on here that knows of a good Citroen
    Workshop ( here in Perth) at a reasonable rate, that is able to diagnose an oil leak coming from engine/ and also minor fluid leaks from power steering. My Citroen Xantia has just come over from Sydney but needs work before I can lic it for WA roads. It has been over the pits and the oil leaks are all that was wrong.
    The Xantia is a 8/96 model with 125k on the clock and is in very good condition for the age. I have all the service history from Sydney including Timing belt done at 67k. I think it is wise to have a new T/ belt done again since it is 8 yrs ago.
    Regards Mark O
    Mar 2011
    Linton.Victoria.
    1,268
    Hi-Timing belt 80,00 k OR 4 YEARS-I would do it YESTERDAY!!!!!!!!-A mate of mine-Bruce Turner started the PCCVWA years ago -your motor is a Pug one & I am sure they will be able to recommend someone to do the belt at minimum.I am sure they will be able to direct you to a Cit mechanic also.
    Pekay
    1000+ Posts zykyra's Avatar
    Apr 2003
    Perth
    1,199
    Hi there, try Bob Senn on 92930576 or Corrado on 93552712, both highly competent but Bob more a Cit specialist, he always seems to have a Xantia lying around. Tell Bob Justin sent you, he'll look after you. Cheers
    1972 DS Pallas
    2015 Clio
    2012 DS4
    Simca Arondes (travaux en cours)
    Lotus Elise Club Racer '12
    In WA? Join THE club ! www.frenchandfantastic.com.au
    NORTH PERTH W.A.
    853
    Default Not only but also
    Mark dyson euro motive Osborne park contact details in the sticky above parts and service
    If it is not hydraulics then any competent workshop could do the job
    1000+ Posts arunine's Avatar
    Port Denison WA 6525
    1,046
    There's Eurocare in Burswood.
    DS 21
    C4 HDI
    Piaggio Fly 125
    11,205
    Quote Originally Posted by renaultmark View Post
    Hi everyone
    Regards Mark O
    The others have given you the places to go for sure. But 8 years on a timing belt??????????????????? I'd be scared to even to turn the key and start it. Are you sure it is that long? This is a critical matter and you must get it done ASAP. I'd sweat just driving it anwhere just to be fixed.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Fellow Frogger! aquinian's Avatar
    WA
    604
    There's a Swiss fellow called Adrian who is very honest, reasonably priced, and competent, who bought West Leederville Autos (Roslyn St) a few years ago. I've taken Pugs to him quite a few times and he has done an excellent job.
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    Dec 2010
    Pelican Point WA
    163
    Thanks for alyour kind advice I have contacted Bob Senn who is up in Kalamunda.
    He has offered to have a look at the Xantis.
    I am aware of the Timing Belt being driven for many years ( far too many for my liking)
    So that wil be sorted, along with the leaking power steering rack and the Engine oil leak(possibly coming from timing cover).
    I will let you all know how it goes once it goes over the pits.
    Mark
    11,205
    Mark
    Bob's a lovely guy and totally honest.
    Now, these engines do develop timing cover gasket leaks after 10-15 years, so nothing unusual there.
    V6 Xantias crack the power steering rigid feed pipe and the 4 cylinder ones are pretty good in that department.
    Don't drive this car further than you must!!!! I'd hesitate to even start it, as I mentioned........
    Dec 2010
    Pelican Point WA
    163
    Default Xantia Fixed
    Hi
    Just letting everyone who put me on to Bob Senn a big thank you.
    The car is now completed and ready for the BIG roadworthy inspection.
    Oil leaks were done, power steering rack completely over hauled.
    Timing belt , tensioner and water pump replaced.
    Engine oil leak was diagnosed as tappet cover gasket...done.
    How nice it is to have this car running how it should.
    Cheers Mark
    Dec 2010
    Pelican Point WA
    163
    This is my Citroen Pride and Joy , after I had the hood lining replaced and a lot of attention to detail on the paint work to bring iot up to shiny white again with a spit and polish.
    Still has NSW plates but might go all out and have Personalized
    ones put on........ any ideas?
    11,205
    Hi
    Cheers Mark
    Good outcome as expected Mark. I met you at Bob's place when you delivered the car and I saw it half done.
    Enjoy it.
