Removing inlet manifold DS23ie
    Feb 2002
    Coolum Beach
    2,048
    Default Removing inlet manifold DS23ie
    Anyone can explain the steps to removing the inlet from a 23ie ? I now need to take a look at fuel pressure regulator and also change number 3 spark plug.
    Keep in mind I am mechanically spastic, so is there anything I might upset while doing this?
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    558
    Try just taking the top half off , it much easier and you can change all the little rubber hoses at the fuel pressure regulator , and you can check the fuel pressure at the same time .
    The plugs can be changed without removing the manifold.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Feb 2002
    Coolum Beach
    2,048
    Quote Originally Posted by Rally View Post
    How do I do that ?
    16,716
    Someone who has done one recently will probably speak up soon... But really all you need to do is pull all of the hoses and lift it off. I can't remember where it's bolted down, but there's nothing to it (it'll be obvious). Careful there is no residual fuel pressure when you pull the cold start injector line (you could just unscrew the cold start injector and leave it in place I guess).
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    How do I do that ?
    Angle Grinder?
    No, seriously. 4 big hose clamps (1 on each each runner) and a couple of locating bolts. One or two near the TB and maybe one or two on the webbing between the runners.
    Feb 2002
    Coolum Beach
    2,048
    DONE ! Thanks everyone.
    Geez that was easy after all. It was an item I was kind of scared of touching. But it went fine.
    Actually it was so easy I am sure I will have to pay for that at some stage, being a DS , probably when I try to re-install it!
