DS BVH parking brake
Results 1 to 2 of 2
    Mar 2003
    369
    Icon5 DS BVH parking brake
    Hi, my DS21 BVH parking brake is useless. It may just need adjustment - an interesting task I understand!
    It may need new pads - I have some good S/H ones.
    I have a factory manual and a copy of the Haynes, but neither lists how to change the pads. I have a good drawing of the unit and its bits but still don't understand how the pads are retained. I am hoping that I don't need to take the calipers off.
    Both manuals show only the cable for a LHD car. Is there an accessible adjustment for our RHD models?
    All bright ideas are most welcome.
    Don
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    Fellow Frogger! CorneSoutAfrica's Avatar
    South Africa
    589
    Hi Don
    I know the manual has got an adjustment screw at the firewall, but can't remember if the handbrake cable on the BVH can be adjusted. I would suggest that you adjust the brakepads at the caliper, a thin 14mm spanner should fit in there to adjust the screw that pushes against the brakepad.
    The only way I know to replace the handbrakepads is unfortunately loosen the handbrake caliper and lift it off/away from the brake disc. PITA job!!
    Best of luck
    Corne
    1968 ID21 break
    1971 DS21 IE BVH Rouge de grenade (Madamoiselle Rouge)
    1974 DS Pallas Sable metalisse My first restoration (Edith) Now BVH
    1973 DS pallas Metallic red. "Rusty"
    1947 Traction Avant
    Modern
    2006 C4 VTS 180 Coupe
    What would life be if we had no courage to attempt anything?
    - Vincent van Gogh
