C5 HDI engine oil
    Feb 2002
    Coolum Beach
    2,048
    Default C5 HDI engine oil
    What's the consensus on a suitable local oil for a 2007 hdi auto with particulate filter as a replacement for the Total one?
    Any recommendation?
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
    10,128
    You probably want to pick a 5W30. It needs to be low SAPS (low metallic ash when burnt) so look for an ACEA rating of C2 I think it is. PSA has it's own oil standard and Total has products meeting that, which is why it's preferred. If the car didn't have a particle filter, you could use many different oils, but you are best to pick one that will leave less metallic ash in the particle filter when it's burnt. It doesn't burn off during the regeneration process and can also clog up the EGR valve. There won't be an immediate problem, so you might be able to get away with the incorrect oil for quite a long time.
    Mar 2005
    920
    Go buy the real thing from Onshore oils in Brisbane. see their website. They have Quartz Ineo ECS .. the REAL thing.
    monbulk
    654
    Default Oils
    Im just biting the bullet on the engine oil and going the elf/total solution. As David said there are some special features of the exhaust. What David didn't say however is that this car also runs a Catalytic Converter (CAT) next to the FAP. CATs can easily be destroyed by oil. Blow a head gasket on any car and the CAT will soon be destroyed. For this reason I would go with the manufacturer's recommendation.
    A search on the net should give you a local supplier.
    BTW I must confess to be a novice with the (new to me) 2.2hdi. I am loving the car to bits and I'm mightily impressed with the engine and dynamics atm, which puts my post in perspective,
    Thanks to Haakon, I will not be going genuine on the auto-trans when I refill the box. But more research to be done on that!
    David
    RYE Vic
    194
    Default Total Oil
    Hi David M if you problems obtaining Total Oil you can contact Total Oil Aust in Vic phone 03 9861 8668.
    Tony
    monbulk
    654
    Default oil
    Thanks Tony,
    Fortunately I have sussed a supplier in Dandenong, so all is good for me. My (first time) mechanic is a Pug specialist and all seems good so far.
    David
