DS Jacking Safety Bar
Results 1 to 11 of 11
    Fellow Frogger! Inspector Clouseau's Avatar
    Dec 2002
    North Coast NSW
    191
    Default DS Jacking Safety Bar
    Is anyone able to provide advice or a design for a jacking safety bar thinggy that can go in the square tubing section? I'm told DSs have a nasty habit of sliding off a garage jack and that a bar and pad inserted in the square tube behind the front wheels will save the front wings - or worse - if the car slides off. Thanks
    8,244
    Icon3
    Quote Originally Posted by Inspector Clouseau View Post
    If you are working on the car the safest option is a pair of car stands, set ride height to the highest position and slip a stand under the square tubing jacking point on both sides.
    Never work under the car only supported by a jack
    08 C5 X7 HDi very Noir
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    Further to sage advice above...
    Support is best obtained from the bottom face of the front jacking point rather than something inserted into the square section.
    If the jacking point is rotted the potential for failure is slightly decreased.
    A stand with screw adjustable height is better than the pin, due to the chance of their being a slight difference in height of the square section of the jacking point for a number of reasons.
    Hope this helps.
    Dec 2002
    North Coast NSW
    191
    OK, thanks. When I bought the car I was told that when it is put up on a hoist (didn't say that earlier) a bar in the square tubing would prevent disasters. I guess any tubing that fits, won't fall out easily and is strong enough, might do the job. I take the point about the jack stands.
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    When I lift my car I use that jacking point but I put a piece of wood between jack and jacking point. But I am afraid that point might break off because of age. I place stand with wood sheet under the car avoiding soft part of under body.
    I am not sure I am doing right though.
    I feel i need to modify the stand and jack plate.
    There is a drawing of jacking thing at end of manual.
    Los Angeles, CA USA
    1,955
    A railroad spike usually fits nicely in the square tubing and gives the jack a nice purchase which will not easily slide off.
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,272
    Default Railway spikes to you, dogs to me...
    Thanks Daffy for the tip on 'Dog spikes', I work at a Railyard and they litter the sidings.
    Before I start taking home the used (I will get permission!) as the sleepers are being changed to concrete over wood with a far better locking method.
    Would there be interest in pre-loved Dog spikes? Re use is the best recycling!
    Dec 2002
    North Coast NSW
    191
    Quote Originally Posted by bluey504 View Post
    Yeah, I'd definitely be interested in some, thanks . Did a Google and they look ideal. Let me know how you want to go about it, freight etc.
    Dandenong Vic
    1,272
    Will have to wait until Tuesday when back at work. Shouldn't be too hard to find a few strays about the place. I'll also measure them up so to confirm that they will do the task. Nothing worse than posting a useless lump of iron across the country!
    Brendan
    Coffs Harbour, NSW, Australia
    625
    Brendan
    What's the problem ? Half the world is DRIVING useless lumps of iron across the country !
    Richard
    Dandenong Vic
    1,272
    Default Didn't want to mention makes...
    So true Richard, way too many useless lumps of iron travelling around.
    Around my area mainly clapped out Camries and Magna's. The owners have the good sense to realise that they are only just transport and dump them when they die an early death from neglect.
    Brendan
