refreshing indicator lens
Results 1 to 11 of 11
    Dec 2004
    Scotland
    135
    Default refreshing indicator lens
    Hi, Has anyone found a way to refresh amber indicator lens, some of mine are very faded and dull. would painting them with clear nail varnish or laquer do the trick, I am a bit reluctant to try in case I ruin them but I am sure someone on here will have successfully sorted theirs
    Kapunda
    493
    I polish them very gently on a buffing wheel using a mild abrasive .They look much better.
    Woody
    Mar 2003
    Tasmania
    1,419
    If the colour is faded try a model shop they have aerosol amber clear paint.
    VERY thin coats on the inside surface.
    Pugs Rule!
    403, now sold
    404, project
    Nov 2002
    Yarrabilba, Queensland
    2,759
    TAMIYA make a few colours of clear paints for models. Amber and red. It's OK if used on the lens inside a light cover. Tried it on a bulb that had faded, lasted a couple of weeks, just never adhered to the glass.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    tweed heads
    1,524
    Default Lenze paint
    You can get it here at parts places ,you could also try a stained glass kit for painting light globes ,from craft shop ,we can also buy coloured globes to fit but that dousnt improve the look of the car pugs
    3,610
    Tamiya lens paint X26 orange.
    Oct 2003
    canberra
    870
    as Brian says buff GENTLY on wheel or sand outside face with fine 1000 grade wet and dry sand paper
    then polish with brasso, it works a treat
    then model shop transparent color on inside of lens, as said already, spray light coats otherwise you get pools of darker color in the hollows
    you can buy lens paint at car shops but it is 10 times the price !!
    Dec 2004
    Scotland
    135
    Looks like a visit to my local craft shop, thanks for the advice.
    cheers
    Helmut
    Mar 2011
    Linton.Victoria.
    1,268
    Hi-Seems like you are speaking about the outside surface of the lens being dodgy-if that is the case the o/s needs polishing as stated.
    If it is the color on the i/s the the paint from the model shop.
    I have imply used paint cutters on the buff - the same as you would use while doing a cut & polish on a car.
    Pekay.
    May 2012
    burnie tasmania
    14
    i used orange globe dye from auto shop had to go to several before i could find it used it on GS indicator lens have used it in several other cars with faded lens worked well cheers andy
    Mar 2005
    Here
    203
    Default Topic died during the last crash so a search didn't find it
    I remember this can up a few years ago - gone into the godaddy eather
    At the links to Turin Imports you will find a red and amber dye that is formulated to revive the lenses. I've seen similar products around other outlets but suggest you go down this route.Turin Imports is in South Australia so a wee bit of stroll from you.
    AMBER LENS TINT
    RED LENS TINT
    The model paints can peel - I had success limited with the Tamiya products on the actual lense in the past but didn't keep that car for very long.
    Recommend strongly that you use a dye, not a paint - when it peels it stuffs up the lens optics and getting it off is a PITA.
    ISFA polishing the plastic lenses see if you can find a Permatex lense cleaner stockist, we use it to polish the 'plastic' windshield / side windows on Sikorsky S70B Seahawk helicopters. Brilliant stuff.
    Permatex Plastic Cleaner 80183 PN 403D Net 16 fl Oz
    Made in Kansas so not sure if you need to get Dorothy in her little red shoes to wish you some to Scotland.
    Yours aye
    Sandgroper
    93' 205GTi
    'don't force it son - use a bigger hammer'
