Dented D
Results 1 to 14 of 14
Thread: Dented D
    Kapunda
    493
    Default Dented D
    This is my friend,s D spec. check out the curvature of the glass.
    16,717
    Gee's your going to have to throw a rock at that window or something. I'd be to worried the window will explode in my face to try and remove/replace the door!
    CitroŽn Tragic UFO's Avatar
    9,791
    I'd be hanging towels on both sides of that window prior to carefully opening the door! Lucky!
    16,717
    Maybe lay some sheets or something over the interior and break the window somehow from a distance. It'll certainly wake you up if it shatters while your right beside it It's amazing it hasn't broken just with the temperature change over the day given how flexed it is
    Kapunda
    493
    Having taken all precautions I carefully removed the door,then after a little surgery I gently addressed it with a large hammer and a block of wood.All innards now successfully removed
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,158
    Quote Originally Posted by brian woodcock View Post
    BRAVO!
    Cheers Gerry
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,272
    Not sure if this is possible, but get the window re-tempered so it doesn't go "Bang, little pieces." When ever it feels like it, others please advise as I've had tempered glass 'screens shatter after being subject to over night low temperatures after taking a hard hit.
    Banned
    sydney, australia
    11,301
    wow i would never have thought glass could bear that sort of deformation and stay in one piece. great photo!
    Fellow Frogger! CorneSoutAfrica's Avatar
    South Africa
    589
    How in the world did that window not break?!?! Nope you are a genius Brian!!
    Corne
    1968 ID21 break
    1971 DS21 IE BVH Rouge de grenade (Madamoiselle Rouge)
    1974 DS Pallas Sable metalisse My first restoration (Edith) Now BVH
    1973 DS pallas Metallic red. "Rusty"
    1947 Traction Avant
    Modern
    2006 C4 VTS 180 Coupe
    What would life be if we had no courage to attempt anything?
    - Vincent van Gogh
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,236
    The deformation is quite amazing. My first car was a vw Type 3 fastback. The rear windows were designed to bend when you opened the rear latch. I always hated using them thinking it would just shatter.
    Matthew
    PS. Who was the bum hole that hit the car?
    Kapunda
    493
    Default Progress
    Having explored many avenues I have been unable to find a late model replacement door.As a last resort I,ve decided to use any early push button Door,The first pic shows part of the door catch panel removed from the damaged door.The second pic shows the panel transplanted into the replacement door.Minor surgery was also required on the front of the door to take the lift up handle.
    Attached Thumbnails Attached Thumbnails Dented D-img_1122.jpg   Dented D-img_1124.jpg
    19,211
    Ah the joys of tetrosyl ! Great stuff for metal filling/finishing.
    Nice job Brian.
    Ram
    Ram is offline
    Sep 2005
    Gayndah 4625
    46
    Default Facinating
    Normally there would be a million pieces.
    Hope you are both keeping well
    Bruce
    10,128
    Quote Originally Posted by Ram View Post
    Do you mean pieces of rust? That would be normal.
