Lexia 3 in Adelaide
Results 1 to 12 of 12
    May 2012
    17
    Default Lexia 3 in Adelaide
    G'day! I have recently bought a C5 MY06 and am keen to purchase a Lexia 3 diagnostic tool.
    Very confused pouring over several forums if it shall be suitable for my C5.
    I'm keen to meet up with anyone in South Australia with a Lexia 3 to try on my car.
    Would appreciate help here.
    Alternatively, if there is a supplier that sells Lexia 3 that will sure fire work on my 2006 C5 HDi 2.0L 6 speed.
    Battery has been replaced before I bought the car and want to reset the Auto close windows on raining and a few other options, I understand the tyre sensors need to be done also.
    Very green, very new to Citroen, Very greatful.
    Feb 2002
    Coolum Beach
    2,048
    Quote Originally Posted by tigger400 View Post
    I ws pretty sure you could set those parameters through your on-board computer. ie on your display panel on the dash. Have a look at your handbook. Otherwise give me your VIN and I'll find out.
    DS Un jour, DS toujours !
    C3 II 2010 Automatique AL4
    Everything's gone bloody automatique!
    May 2012
    17
    Quote Originally Posted by harrisson_citroen View Post
    Many thanks for your reply, the VIN # is;
    VF7RERHRJ 76754499
    I was not given the hand book as the previous owner had lost it, so will be sourcing one,,,,if any one can help there as well
    Thank you
    Feb 2002
    Coolum Beach
    2,048
    VF7RERHRJ 76754499
    Thank you
    I know how daunting it is to acquire a C5 and not know much about them, and it's not as if the Citroen dealer are helpful.
    So in the meantime I have scrounged the details of your particulat vehicle from the Citroen facdata.
    Keep this safe somewhere, you will find you will need it iin the future.:
    C5 II BREAK 5PTES 2. HDi 138 FAP BVA 6 RAPPORTS
    Caractéristiques du véhicule
    Ligne de produit
    C5 II
    N°APV/PR
    10756 CJ 1 0162
    Date de Début de Garantie
    31/07/2006
    OPB
    A040
    LIGNE DE PRODUIT
    C5 II
    SILHOUETTE
    BREAK 5PTES
    FINITION
    HAUTE MOYENNE
    MOTEUR
    DIESEL TURBO DW10BTED4 FAP
    TRANSMISSION
    BVA 6 RAPPORTS
    TYPE DE PEINTURE
    PEINTURE METALLISEE VERNIE
    COULEUR DE CAISSE
    EZR - PEINTURE GRIS ALUMINIUM
    TYPE D’HABILLAGE INTÉRIEUR
    CUIR CLAUDIA "Q1"
    COULEUR DE GARNISSAGE
    "FC"
    BOITE DE VITESSES (CARACTÉRISTIQUES)
    BVA AM6B
    MOTEUR (TYPE)
    MOTEUR TYPE EW/DW
    MONOGRAMME COMPLÉMENTAIRE, DIVERS
    SANS MONOGRAMME COMPLEMENTAIRE
    MONOGRAMME
    C5
    Caractéristiques véhicule
    FINITION
    HAUTE MOYENNE
    TYPE DE PEINTURE
    COULEUR DE CAISSE
    CUIR CLAUDIA "Q1"
    "FC"
    BVA AM6B
    DIRECTION
    DIRECTION ASSISTANCE NON VARIABLE
    COUPLE TACHYMÈTRE
    CT 22 X NO
    Alimentation moteur
    MOTEUR
    DÉTECTEUR D’EAU FILTRE À GAZOLE
    AVEC DETECTEUR EAU FILTRE GASOIL
    CARBURANT
    GAZOLE
    DÉPOLLUTION (MOTEUR)
    DEPOLLUTION EURO 4(MOTEUR)
    MOTEUR (TYPE)
    MOTEUR TYPE EW/DW
    REFROIDISSEMENT D’HUILE
    ECHANGEUR SUR MOTEUR ET BV
    MOTEUR REFROIDISSEMENT
    RADIATEUR EP:32 - 21 DM2 ALU BRASE
    RÉCHAUFFAGE CIRCUIT GAZ CARTER
    SANS RECHAUFFAGE CIRCUIT GAZ CARTER
    VARIATION PUISSANCE (MOTEUR)
    PUISSANCE STANDARD
    DISPOSITIF (ANTIPOLLUTION)
    RECIRCULATION GAZ ECHAPPEMENT "EGR"
    DÉPOLLUTION TECHNIQUE VÉHICULE
    DEPOLLUTION TECHNIQUE VEHICULE EURO 4
    FILTRE À PARTICULE
    FILTRE A PARTICULES
    VENTILATEUR
    1 VENTILATEUR ELECTRONIQUE CDE INTEGREE 160W
    VARIANTE ASSOCIÉE INJECTION
    SYSTEME INJECTION SIEMENS
    FILTRE RÉSERVOIR
    FILTRE RESERVOIR INTERIEUR
    Boîte de vitesses Transmission
    TRANSMISSION
    BVA 6 RAPPORTS
    BVA AM6B
    COUPLE RAPPORT
    CP 15 X 53
    COUPLE TACHYMÈTRE
    CT 22 X NO
    STYLE ROUE
    ROUE HUNGARO 16 POUCES
    EMBRAYAGE
    SANS EMBRAYAGE
    JOINT COTÉ ROUE
    JOINT COTE ROUE AC 3300I
    JOINT COTÉ PONT
    JOINT COTE PONT AAR 3300I
    PNEUMATIQUE (DIMENSIONS, TYPE)
    PNEU 215X55X16 W
    ROUE (TYPE)
    MONTAGE ROUE ALLIAGE 1
    INDICATEUR DE PERTE DE PRESSION DE GONFLAGE
    INDICATEUR PERTE PRESSION GONFLAGE
    BOITE DE VITESSES TYPE
    BVA AM6
    Suspension Direction Freinage
    DIRECTION
    SUSPENSION
    SUSPENSION NORMALE
    SUSPENSION ACTIVE
    SUSPENSION HYDRACTIVE 3 PLUS REGLAGE AUTO
    CONTRÔLE DYNAMIQUE DE STABILITÉ
    AVEC SYSTEME ESP
    DIRECTION (FONCTIONNEMENT)
    DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
    Carrosserie Equipements
    ENJOLIVEMENT LATÉRAL (ASPECT)
    PROTECTEURS LATERAUX COULEUR CAISSE
    ENJOLIVEMENT LATÉRAL (DIMENSION)
    PROTECTEURS LATERAUX PLASTIQUE + CHROME
    ENJOLIVEUR ROUE (STYLE)
    TYPE HUNGARO
    FEU D’ÉCLAIRAGE DE SEUIL
    FEU ECLAIRAGE DE SEUIL
    COMPLÉMENT DE PROTECTION (SOUS MOTEUR)
    SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
    FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR
    RETRO EXT RABATTABLE ELECTRIQUE SANS MEMOIRE
    ESSUIE-VITRE AVANT
    ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
    ESSUIE-VITRE ARRIÈRE
    ESSUIE-VITRE AR
    ESSUIE-PROJECTEUR
    ESSUIE-PROJECTEUR
    OBTURATEUR FACE AVANT
    SANS OBTURATEUR FACE AV
    VITRE VOLET ARRIÈRE
    VITRE VOLET AR OUVRANTE
    PORTE-BAGAGES
    MONTAGE AVEC BARRES DE TOIT
    PROJECTEUR ANTIBROUILLARD
    PROJECTEURS ANTI BROUILLARD
    TOIT OUVRANT
    TOIT FIXE
    ENJOLIVEMENT PARE-CHOCS
    BANDEAU DE PARE-CHOCS COULEUR CAISSE
    VITRE (TYPE)
    PARE-BRISE ATHERMIQUE
    PACK LOOK EXTÉRIEUR
    PACK LOOK EXTERIEUR COULEUR CAISSE
    Equipement intérieur
    CUIR CLAUDIA "Q1"
    ALARME ANTIVOL
    SANS ALARME ANTIVOL
    ACCOUDOIR ASSISE ARRIÈRE
    AVEC ACCOUDOIR AR
    CLIMAT (TEMPÉRATURE AMBIANTE)
    PAYS CHAUDS
    GRADUATION VITESSES
    GRADUATION EN KM/H
    COTÉ DE CONDUITE (POSTE DE CONDUITE)
    CONDUITE A DROITE
    CHAUFFAGE ADDITIONNEL
    SANS CHAUFFAGE ADDITIONNEL
    EQUIPEMENT PLANCHE DE BORD
    DECOR LAQUE NOIRE
    GARNISSAGE VOLUME CHARGEMENT
    TAPIS COFFRE PVC+COTES MOQUETTE
    RANGEMENT SOUS SIÈGE
    1 TIROIR DE RANGEMENT SOUS SIEGE
    GARNISSAGE DE PORTE
    DECOR LAQUE NOIRE
    HAUT-PARLEUR
    4 HP AV (2 TW + 2 AV) + 2 HP AR
    COMMANDE D’AUTORADIO
    CDE AUTO-RADIO A DISTANCE
    ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT)
    SANS STORE AR
    REHAUSSE ASSISE AVANT PASSAGER
    REHAUSSE PASSAGER REGLAGE AVANT
    COMMANDE ASSISE AVANT CONDUCTEUR
    CDE SIEGE AV ELECT CONDUCTEUR
    COMMANDE ASSISE AVANT PASSAGER
    CDE SIEGE AV ELECT PASSAGER
    ELÉMENTS DE GARNISSAGE INTÉRIEUR
    GARNISSAGE PIED CENTRAL TISSU + CUSTODE POLYPRO
    ACCOUDOIR ASSISE AVANT
    ACCOUDOIRS AVANT CONDUCTEUR ET PASSAGER
    COMPACT DISQUE
    SANS MONTAGE COMPACT DISQUE
    SYSTÈME DE NAVIGATION
    SANS SYSTEME NAVIGATION
    LAMPES DE PROJECTEURS
    LAMPE A DECHARGE
    LÈVE-VITRE ARRIÈRE
    LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
    LECTEUR D’INFORMATIONS ROUTIÈRES
    SANS SURVEILLANCE TRAJECTOIRE LATERALE
    AFFICHEUR
    AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
    MIROIR DE COURTOISIE
    CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
    INDICATEUR D’HUILE
    RECEPTEUR TEMPERATURE
    NAPPE CHAUFFANTE
    SIEGE NON CHAUFFANT
    ECLAIRAGE BAS HABITACLE
    ECLAIRAGE CAVE A PIEDS COND + PASS AV
    PROTECTION PASSAGER ARRIÈRE
    AVEC PROTECTION PASSAGER AR
    NEUTRALISATION COUSSIN GONFLABLE
    SANS NEUTRALISATION COUSSIN GONFLABLE
    PROJECTEUR CORRECTEUR ASSIETTE
    REGLAGE AUTOMATIQUE PROJECTEURS
    RÉCEPTEUR RADIO
    SYSTEME AUDIO COMPACT DISC RDS "RD4"
    RÉFRIGÉRATION
    REFRIGERATION AUTOMATIQUE
    RÉGULATEUR DE VITESSES
    REGULATEUR ET LIMITEUR VITESSE
    RÉTROVISEUR INTÉRIEUR
    RETROVISEUR INT JOUR-NUIT ELECTROCHROME
    RÉGULATION CLIMATISATION / TEMPÉRATURE
    REFRIGERATION AUTOMATIQUE BI-ZONE
    RANGEMENT VOLUME CHARGEMENT
    AVEC FILET DANS COFFRE
    TUNER-RADIO
    MONO TUNER RADIO
    DÉTECTION D’OBSTACLE
    DETECTEUR OBSTACLE RADAR AVANT ARRIERE
    AMPLI-ÉQUALISEUR
    SANS AMPLI EQUALISEUR
    COMMANDE VERROUILLAGE
    VERROUILLAGE SUPER CONDAMNATION
    VITRE (TYPE)
    VOLANT
    VOLANT MOUSSE 4 BRAS
    VENTILATEUR
    PACK RADIO / INFORMATION / COMMUNICATION
    RD4
    MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT)
    MAINTIEN LOMBAIRE AUTOMATIQUE
    Electricité
    ALTERNATEUR
    ALTERNATEUR CLASSE 15
    BATTERIE
    BATTERIE L3 450
    DÉMARREUR
    DEMARREUR CLASSE 6+
    ECLAIREMENT PARTICULIER
    ALLUMAGE AUTOMATIQUE FEUX
    LAMPE A DECHARGE
    FRÉQUENCE RADIO
    FREQUENCE RADIO ASIE
    Marques d'équipements
    Divers
    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION
    STANDARD
    ATMOSPHÈRE
    ATMOSPHERE POUSSIERES
    CONDUITE A DROITE
    COTÉ CIRCULATION
    CIRCULATION A GAUCHE
    TRIANGLE DE PRÉSIGNALISATION
    SANS TRIANGLE PRESIGNALISATION
    Haut de page
    May 2012
    17
    Thanks for the detail, I shall save it, though not sure what it all means.
    Still after a diagnostic tool and hand book.
    Removing EGR valve tomorrow to clean it as I think it is causing the motor to loose power when I plant it.
    Thanks again, Steven
    May 2012
    17
    I took the EGR valve and inspected it, was free to move when manually actuating it and sealed air tight, couldn't test the electrical actuating motor though, have no reason to suspect it is faulty.
    Read the MAF sensor could be faulty, will have a look at this tomorrow.
    Still after a Lexia recomendation and c5 2006 handbook to copy
    Cheers, Steven
    May 2012
    17
    Ok, pulled the MAF out and sprayed it with CRC MAF cleaner obtained from Autobarn at $25 a can.
    Engine fault light went out, pulled to higher revs-about 3,500-(from 2,500 before), but still hit a brick wall there.
    Will give it another clean, but suspect MAF sensor is not what it should be.
    Any input about my findings and guesses would be appreciated.
    Sep 2003
    North Parramatta
    4,012
    Perhaps tigger may appreciate it more if it were in English?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    May 2012
    17
    Indeed!!
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,048
    Hi Steven,
    You should go buy a Haynes C5 manual as it will cover your car, engine and gearbox.
    I have a Lexia with 2010 software and it works on my C5X7 that has the same engine and gearbox as your car.
    I have also logged in an additional tyre pressure sensor for a new mag spare wheel so I have some experience with that.
    This engine will only rev to 4000 rpm anyway and all the torque is around 2000 so I wouldn't worry about going higher.
    Ken
    May 2012
    17
    Quote Originally Posted by Ken W View Post
    Hi Steven,
    Ken
    Many thanks for your post Ken.
    Am still keen for obtaining a Lexia, from where did you obtain it, did the software come with it, is it a lexia 3 and how much?
    I'm not wanting anything extraordinary out of the car, just for it to perform to specs. The rev issue wreaks havoc on gear box in sports mode as it won't shift up expecting more revs.
    I usually drive like I'm on my way to Sunday church, bit want it to perform when needed.
    Before cleaning the MAF sensor, I overtook a road train and power died at 2,500, I had to brake and return behind, not wanting to have that happen again, I'll have the engine working as it should.
    Thanks for your posting, hope to hear from you soon
    North Brisbane
    2,048
    Hi,
    Have you changed the fuel filter? These block up very easily on any diesel fuel that is not Shell or BP. A blocked fuel filter will cause surging, loss of power at revs, feeling like the turbo isnot working properly.
    I just bought my Lexia on Ebay. It came with CD of software and I managed to get one with cables to suit a BX, Xantia/XM series one (30 pin connector) and C series OBD connector. You will only need the OBD cable for your C5.
    You will need a computer with at least a 1024x768 screen a CD drive and a USB port to run the Lexia. The CD has instructions on how to install the Lexia or Planet Peugeot software. I found it best to use an older laptop and dedicate it to the task as the software version I used seemed to upset the virus scanners.
    Ken W
