DS: Lower when parked?
Results 1 to 9 of 9
    Fellow Frogger! Inspector Clouseau's Avatar
    Dec 2002
    North Coast NSW
    188
    Default DS: Lower when parked?
    I expect this will sound like a dumb question to aficionados but, as a new owner, I don't know what the answer is. I raise my car to 3 to put it in the garage. Is it OK to just leave it there once parked or is it best to lower fully? I would have thought lowering would quickly take any pressure off the spheres, but I've been told it doesn't matter. What are the learned opinions of AFers?
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    641
    Why do you raise it to 3?
    I just leave them on normal. Putting it to low will only take you longer for it to raise up when you want a drive. Whatever height its on it will only sink to bumps stops over time anyway.
    Citroen Car Club of New South Wales member.
    My Citroen ID21F can be seen here http://www.flickr.com/photos/frontdr...7605999522616/
    16,328
    I quite often do .... It depends where there leaking from at the time. If you have return leaks in the suspension boots/lines, it'll leak less if you drop it down
    seeya
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    It doesn't matter what position the car is in when parked.
    Most people simply leave the car in normal height.
    The spheres don't need any special treatment from their owner, other than to checke the pressures every couple of years and keep them topped up. Your reward for this will be a continuing superb ride, provided you are using the correct spheres.
    May 2011
    Leonay, NSW
    95
    I certainly need to raise my DS a little when driving in to the garage at the top of our reasonably steep drive. Otherwise, the exhaust will scrape at the bracket for the flexible joint when passing over the join with the level garage floor.
    Keeping the adjusting handle in the raised position makes sure that I remember to have the car at the right height when driving out next time.
    10,705
    Quote Originally Posted by kenlin View Post
    Perfect logic. I come up a notch to get into the work carpark and leave it there so the height is right when I leave.
    Makes not the slightest difference to the spheres, but Shane's point is good! If you release the pressure it won't leak in other places if they are misbehaving.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,300
    At any of the intermediate heights the hydraulic pressure in the front and rear suspension systems depends on the load upon them. Front and rear pressures will be different. If no appreciable additional load is placed in the car (e.g., the boot is not full of bricks), system pressure will not be high. Suspension system pressure is only high if you place the lever on full height and leave it there until the pump cuts out. At that point, the suspension is at full hydraulic system pressure. I prefer not to leave a DS at that pressure. Any hydraulic car, actually. When I am raising the suspension to change a wheel, I generally turn the engine off as soon as the suspension arms have reached the bump stops. That way the pressure in the lines is not much more than normal pressure. My answer to your question is to either leave it on low or one of the intermediate settings, but not on high.
    Roger
    Dec 2002
    North Coast NSW
    188
    Thanks all for the advice. I need to put mine up a notch to get it safely over a drain on a roadbase driveway. I think the hydraulics are in good condition as it takes quite a while to sink down once parked - I suppose that's the test ??
    Oct 2011
    Toowoomba
    647
    Default You forgot the cat!
    Quote Originally Posted by Inspector Clouseau View Post
    The D did have a nickname, the Parisian cat killer... I used to park mine low to stop it flattening the stubbourn old yellow cat.
    I've also noted that the suspension boots, particularly the rears. last longer if the car is parked on stands. Rounds of firewood under the side jack points and under the towbar if it has one.
    The various CX I have which still go are parked on bricks to stop the suspension boots cracking.
    Bruce.
